Tracker window crank removal
  • 2110 Views
Offline bigred
« on: June 02, 2009, 08:30:21 AM »
Does anyone know an easy way to remove the window crank on a 94 Tracker LSI?
Offline fordem
Re: Tracker window crank removal
« Reply #1 on: June 02, 2009, 09:02:39 AM »
Assuming they're like the cranks on most vehicles - grab a shop rag, twist it into a rope, pass it behind the handle so that it wraps aginst the winder shaft and the pull the ends in a back & forth motion - it will snag one end of the clip and pull it free.
« Reply #2 on: June 02, 2009, 12:28:40 PM »
I use the same technique with the edge of a t-shirt (use one you don't mind getting cut up), as it seems to work the easiest for me. There's the crank, a plastic "o-ring", and the door panel. Try to work the edge of the shirt between the o-ring and the door panel.
Try to get the shirt somewhere past the 180* arc, and work it back and forth (in a sawing motion) a few times while working around the shaft. See if the crank comes off. If not, continue this motion and checking to see if the crank will come off. I usually work in 90* increments. After a little practice, you shouldn't ever have to do more than the full 360* around the window crank shaft before popping the clip off. BE CAREFUL to not loose that clip, it may or may not want to "spring" off.
When you out the window crank back on, it's quite easy (the reason for the design). Just put the clip back on the window crank, where the two V notiches (from clip) fit into the two slotted holes on the window crank. You should hear these V notches click into place when you put the crank back on. Don't forget to put the o-ring thing on first... ask me how I know  ::)
This guy uses the specialty tool, but should give you an idea of what you need to do:
You're basically trying to "catch" or "snag" one of the pieces of that clip and work it off the crank.
Offline bigred
« Reply #3 on: June 02, 2009, 01:16:40 PM »
Thanks guys, I'll give it another try when I get off work.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #4 on: June 02, 2009, 01:57:36 PM »
i use a small pick/hook type screwdriver to reach in and pull the clip out, if you press the door panel in and sneak a peak behind the crank you will see it in there
-Lance
« Reply #5 on: June 02, 2009, 03:33:20 PM »
Or buy the tool designed for the job. Most parts stores and tool stores have them cheap.
