Noise from Speedo
  • 9 Replies
  • 3026 Views
Offline TrackerJoe
  • 32
Noise from Speedo
« on: June 16, 2009, 03:24:26 PM »
I have a 97 Tracker and I am getting in whining/grinding noise that is speed related not rpm. Can i remove the cluster and grease the speedo input or something? thanks
1997 Tracker 5 speed 2WD :( getting a locker and always on the lookout for parts for the 4WD conversion
Re: Noise from Speedo
« Reply #1 on: June 16, 2009, 05:05:57 PM »
Does the speedo jump around a bit?  If so it is probably your cluster and not the cable.
Offline TrackerJoe
  • 32
« Reply #2 on: June 16, 2009, 05:12:02 PM »
No, it sweeps pretty smoothly
Offline 4Zstracker
  • 250
« Reply #3 on: June 16, 2009, 10:30:17 PM »
That noise happened to me in my 96, for a while it was just noise, then the needle started jumping around, and then one day the needle just popped right off and fell down to the bottom of the cluster.
I ended up swapping the whole cluster from a parts truck. Dint change the cable, and it still works just fine.
if ya always do what ya always done, you always gonna get what ya always got...
Offline Carnage
  • 2453
« Reply #4 on: June 17, 2009, 09:32:40 AM »
this is quite a common problem
relatively easy fix but you really gotta get in there
ive been living with the noise for a year now
Offline TrackerJoe
  • 32
« Reply #5 on: June 19, 2009, 06:40:49 AM »
So what is the easy fix?
« Reply #6 on: June 19, 2009, 10:20:14 AM »
A new cluster.  :)
You can remove the cluster without having to move the steering wheel, you just need to take your time.
« Reply #7 on: June 22, 2009, 01:17:38 PM »
I hit my windshield washer a lot when playing with the cluster, but it can all be done through the wheel. Takes a little time & patience. Sometimes I wonder if it'd be a little quicker to pull the steering wheel, but I've never tried it yet...
Offline 4Zstracker
  • 250
« Reply #8 on: June 22, 2009, 10:49:03 PM »
Only prob with removing the steering wheel, is the air bag. Those arent toys lemme tell ya.
At least thats for me in my 96, older trucks dint have air bags ( I dont think, correct me if im wrong ).
« Reply #9 on: June 26, 2009, 03:46:14 PM »
Air bag is no big deal. Just pull the fuse (in a separate yellow box under dash driver's side). When the air bag gets unplugged, be cautious of static electricity. Don't touch the electrical connectors unnecessairly, and you'll be fine. I think my air bags were all of 2 bolts & 2 connectors. Actually, gaining access to the steering wheel bolt was EASIER on my air bag model than it was on my non airbag model.
