ISKY power cam anyone any good?
  • 8171 Views
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« on: August 17, 2004, 04:32:26 AM »
Hey guys
Just got off the phone with Jim at rocky road im thinking of gettinr the ISKY power cam what are ur thaughts on it.
I do alot of highway and city driving i want some more top end power anyone help thanks.
01 GRAND VITARA
Offline idaholwb
  • 772
Re: ISKY power cam anyone any good?
« Reply #1 on: August 17, 2004, 09:59:49 AM »
 With a header, K&N air filter, and bigger exhaust, that cam would be great. To give you a little idea of sizing, the Isky Torquer cam is almost exactly the same lift and duration as the stock 1/6 8v cam. The Power cam in a 1.3 requires the change of the valve springs due to the extra lift that the cam has, but in a 1.6 8v the springs don't need changing besause it doesn't lift too high for the size and placement of the springs. It would be a very good all around cam for the 1.6 8v.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline szabotage
  • 114
  • snaggletooth
« Reply #2 on: August 17, 2004, 12:13:01 PM »
i used the isky midrange in a 1.3 sammi engine: excellent power upgrade
installed it into a 1.6 with a 1.3 head carb'd better torque than the 1.6 efi
instaled it into the 1.6 efi, no power/torque gains whatsoever
check out colt cams in BC he makes a cam suitable for the 1.6 8V
http://coltcams.com/
best of all he's in canada so no over the border tax and he's prompt from what I heard
mike
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #3 on: August 17, 2004, 04:32:34 PM »
I'll put in a vote for colt cams, I'm running his high torque in mine. Works very well from right off idle up to about 4000rpm. He will also build a cam to suit your needs. Send him an email, he is very helpful.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline nighthawk801
  • 51
  • Zuki Lover
    • ClubGM
« Reply #4 on: August 17, 2004, 06:55:08 PM »
If it's about the same lift and duration it can't really add much power if any, can it?? Is it just a cam designed to modify the torque curve a little?
I personally want a cam that increases power. The Calmini cam is cheap and says that it adds power... so I'm leaning toward that at the moment.
90 Sidekick 2-dr w/ hardtop, 250k mi.
2-3" susp., 1.5" body, 4.4:1 low, ARB rear, onboard air.
http://www.clubgm.com/redzuki
89 Sidekick softtop Stock, 180k mi.
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #5 on: August 17, 2004, 07:18:02 PM »
I think that is low to midrange power gains with the Calmini cam... As far as most of my research (note: research, not experience!) the ISKY should be nice, but COLTCAMS has me interested... Any one else got this guys work in their rig?
steveo
