Calmini lifted my Vitara too much!
  • 79 Replies
  • 20965 Views
0 Members and 33 Guests are viewing this topic.
Offline olija
  • 770
    • Check out my cardomain
Re: Calmini lifted my Vitara too much!
« Reply #75 on: December 02, 2009, 07:11:28 PM »
No, I don't have my stock springs anymore, which sucks because I would have done just what you said MONTHS ago! I've been corresponding with Dave from Bits4Vits and he is running 3" of lift on his GV with the 2.25" extensions so I'm thinking I probably should have got those.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #76 on: December 02, 2009, 10:20:56 PM »
how about using the bds extensions with a limiting strap? that way you don't top out your strut anymore?
may be an alternative?
Offline olija
  • 770
« Reply #77 on: December 07, 2009, 09:23:53 PM »
That part wouldn't be the problem, the problem would be the severe bottoming out that results from only having 3.5" of uptravel. I ordered the Bits4Vits 2.25" extenders this morning, maybe if they get here by the weekend I'll put them in on Saturday.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #78 on: December 07, 2009, 11:14:02 PM »
ok then, make an extension for your bump stop, its not hard they unscrew. so you can make a spacer that screws in where the stock rubber stop was, than screw the stock rubber to the spacer. make a pipe bomb with a bolt at one end and a nut on the other.
just pull the spring out, hook the strut back up and dry cycle the susp to full stuff, that way you can see how much longer you need the bumpstop to be, so the strut does not bottom out. alot of suspension lift kits come with bumpstop extensions for this reason....
i still need to do it to mine. i have not had the issues you have tho (yet) I always moniter the "dirt" line on the shaft (hehehe) to make sure im not bottoming it out, so far so good.
the front ends on these trucks may need a bit more tweeking than the sidekick ifs, but i think we can figure it out.....
-Lance
Offline bzzr2
  • 1011
« Reply #79 on: December 08, 2009, 08:54:02 AM »
i've popped a few strut mounts but never completely killed a strut to the point it was not driveable.  i agree that a front extension to the bumpstop is likely a good idea.  bits4vits has bumpstop extensions if you need em.
09 taco reg cab short box 4x4
