Do you carry a shovel, and How?
  • 9 Replies
  • 3390 Views
« on: June 25, 2009, 12:09:08 PM »
I was recently given a gift of a real nice shovel by my forest firefighter buddy. Now I need to find a way to carry it, outside, without having it stolen. I have a swing away spare tire/jerry can holder I can rig a mount to. Right now it's just secured to the back of my spare with a strap. It's secure, but I'd like something more lockable. Any ideas?
Offline bzzr2
  • 1011
Re: Do you carry a shovel, and How?
« Reply #1 on: June 25, 2009, 12:34:44 PM »
i keep mine inside, i have a giant rubber duffel bag full of recovery gear....  never seen a way to lock a 'nice' shovel, i know some of them are pricey and should be locked!  good luck.
BTW, anybody that reads this who doesn't carry a shovel should get on board and get one, 2nd best recovery item ever.
09 taco reg cab short box 4x4
Offline rascott
  • 669
  • 15
« Reply #2 on: June 25, 2009, 01:55:21 PM »
i carry mine, strapped thru the spare tire rim, between the tire and tail gate. use a ratchet strap.
i don't worry too much about someone stealing it.
i worry about other things disappearing though. hate to have to worry that way......
« Reply #3 on: June 25, 2009, 03:41:40 PM »
OK, it's just a shovel, nothing really special about it. I guess locking it isn't as important as securing it so someone doesn't use it to smash my windows and get inside!
Offline Freak
  • 129
    • Freakreation
« Reply #4 on: June 25, 2009, 04:35:41 PM »
 How about a set of hoodpins. You could weld the studs to your tire carrier then drill holes on the shovel head and handle and use a small padlock on one of the studs and a pin on the other! Small rubber bushings would keep it from rattling.
Just a thought!
« Reply #5 on: June 25, 2009, 06:07:06 PM »
I have mine mounted to a Garvin roof rack, if you look closely it is just four bolts with wing nuts on the outside, I was going to drill small holes through the 4 inch bolts and use little brass or stainless pad locks, or use the new tuner lugs that resemble big torx bolts if I can find them in the same thread pitch.
« Last Edit: June 25, 2009, 06:09:08 PM by chevytracker »
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #6 on: June 25, 2009, 06:19:03 PM »
I keep mine inside  ;D I have one of  these combo shovels
http://www.4x4equip.com.au/listProduct/4x4+Accessories/Off+Road+Shovels
« Reply #7 on: June 26, 2009, 04:31:13 AM »
ChevyTracker, Nice Rig! Tuner lugs and a couple of studs, now that's an idea.  I do have a roof rack, but only put it on when I'm going to use it. The Tracker won't fit through my garage door with it on!  Freak, the hood pins idea sounds like a good one too, I thought about doing something like that with bolts, but am concerned about weakening the shovel handle by drilling holes in it. It is some kind of composite so it may be strong enough. Cj, I have been carrying mine inside too, it fits very nicely behind the back seat, but I finally got to use it, and putting it back there all muddy and dirty is just a pita. Thanks for the ideas guys!
« Reply #8 on: June 26, 2009, 02:54:29 PM »
I just carry a military folding shovel. I like the German single-fold better than the US tri-fold style. I'm thinking about mounting it the same way chevytracker did... except on a swing-away.
http://www.fatiguesarmynavy.com/store/subcat/225/Military_Surplus_Shovels
Offline cj
  • 1276
« Reply #9 on: June 26, 2009, 04:29:48 PM »
Mine breaks down and each piece has its own pocket in the storage bag so even if it's dirty it doesn't make a mess inside the vehicle and its easy eneogh to wash the bag when you get home, To be honest it sees most use as a long handle shovel when stuck in snow or sand so mud generally isn't that big a deal anyway most of the time.
