Flat Towing a Kicker
  • 1913 Views
Offline nighthawk801
  • 51
  • Zuki Lover
    • ClubGM
« on: August 15, 2004, 06:18:57 PM »
We flat towed my 90 Kick out to do some wheeling last weekend and made at least one major mistake... we forgot about the steering wheel locking, so with no key in the ignition the wheels locked and started barking on turns.
My dad is wondering now, do you recommend we leave both the tranny and t-case in neutral or leave the t-case in 2WD Hi while the tranny is in neutral? We left the t-case in Hi so that the spinning gears will keep everything lubricated. Is this necessary or should we put the t-case in neutral as well?
Thanks guys.
90 Sidekick 2-dr w/ hardtop, 250k mi.
2-3" susp., 1.5" body, 4.4:1 low, ARB rear, onboard air.
http://www.clubgm.com/redzuki
89 Sidekick softtop Stock, 180k mi.
Offline Mike71
  • 1449
Re: Flat Towing a Kicker
« Reply #1 on: August 16, 2004, 01:49:54 AM »
u should start the kick every 100 or so miles anyways so i wouldnt worry about lube
Offline RBEBY
  • 21
  • BEACHIN
« Reply #2 on: August 16, 2004, 04:30:22 AM »
Have the trans in 2nd gear and the transfef case in neutral ,
lockout hubs in free or disconect  the rear driveshaft with the front hubs in freewheel.
Offline zukiboy
  • 42
  • Wheel Forever !!!
« Reply #3 on: August 16, 2004, 05:34:31 PM »
I agree with RBEBY. Trans in 2nd and transfer in neutral with hubs unlocked.
88 sami
3"lift 30's
No matter where you are there you'll be
