Bumper mounted lights...
  • 8 Replies
  • 3088 Views
« on: July 02, 2009, 09:50:53 AM »
Where can I source some bumper-mounted head / fog / spot lights like these (or square... or whatever):
How do you think they're mounted up? A rubber gasket, or some kind of mounting tab on the back side of the bumper?
Offline sammypro.com
  • 153
Re: Bumper mounted lights...
« Reply #1 on: July 02, 2009, 03:01:58 PM »
piaa.com
they should have it.
That is one nice lookin bumper, whos is it?
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some freakin' muscle.
http://www.facebook.com/#!/sammypro
« Reply #2 on: July 02, 2009, 04:03:09 PM »
Don't know. I saw it out at KOH. Went to look for the owner a few times, and couldn't locate him.
« Reply #3 on: July 03, 2009, 06:45:06 PM »
Check out Pilot Automotives two catalogs on lights - they give actual measurements and specify what light beam pattern each light produces. I am sure their lights are well built, they have head lights, tail lights even angel eye light kits.
http://www.pilotautomotive.com/pdfs/Pilot_performance_lighting1.pdf
http://www.pilotautomotive.com/pdfs/Pilot_performance_lighting2.pdf
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
« Reply #4 on: July 03, 2009, 07:12:17 PM »
« Reply #5 on: July 04, 2009, 08:32:52 AM »
So which is it? A fog lamp with a wide, low beam, or a drving light with a narrow far reaching beam?
Both. I like to see far & wide.
« Reply #6 on: July 04, 2009, 06:37:33 PM »
I noticed the same thing when I was looking at lights, it appears manufactures have different definitions for fog, driving and auxiliary lights.  It got so frustrating for me, if I saw lights on a truck I liked I would wait by the truck and ask the owner to fire up their lights and view for myself.
I would assume smaller diameter lights (under 3 inches) would be wide short distance beam, large diameter (5+ inch) would be long range beam or pencil beam type, this is just my opinion.
I am looking for amber fog lights to mount below the headlights for fowl weather and see ones with clear lenses listed as fog lights.  Wouldn't a clear white light worsen foul weather conditions?
Keep us posted, if I can get a pic, I will upload my lights patterns and distance from vehicle they can still reflect light off a standard bicycle reflector.
Offline blacktrack99
  • 254
« Reply #7 on: July 04, 2009, 07:25:06 PM »
I live in Hammer country.  I'll keep an eye out for that rig and try to get some info if I do.  No mistaking that bumper.
« Reply #8 on: July 05, 2009, 09:10:48 AM »
Unfortunately there is no relationship whatsoever between size and function - it's a matter of reflector and lens design - just as an example - take a look at the the LightForce range - you can change the beam pattern with a snap-on filter.
Another lamp you can look at is the Hella 500 range (available at your local Walmart) - thre is the Hella 500, which is a fog light with a fluted lens and the Hella 500FF which is a drving light with a clear lens, both are 6" diameter and actually use the same reflector.
For what it's worth - I share your frustration when it comes to auxiliary lighting, however, I don't see it as different manufacturer's having different definitions, I see it as the less expensive manufacturers having no set standards - take a look at Pilot's website, you'll find they list the PL-203W as both a driving light with a narrow far reaching beam and a "projector fog" with a "wide, low beam much like a standard fog lamp"
