Samurai vs. Tracker DS flanges
  • 2077 Views
Offline explosivo
  • 3157
« on: August 15, 2004, 04:29:21 AM »
In the front, will a kick driveshaft bolt up to a Samurai axle?
omghi2.us[/url]
Re: Samurai vs. Tracker DS flanges
« Reply #1 on: August 15, 2004, 06:29:05 AM »
The flanges are different in bolt spacing,
but you could use the Sammie flange on
a Kick shaft by swapping when you install
new U-joints
Offline explosivo
  • 3157
« Reply #2 on: August 15, 2004, 07:41:06 AM »
So they use the same U-joint?
That's what I'll do if I follow through with the Sammy SAS plan, then. Just another part to add to the ever-growing list :)
« Last Edit: August 15, 2004, 07:42:25 AM by explosivo »
omghi2.us[/url]
Offline rockrat
  • 196
  • Got Ringr
« Reply #3 on: August 16, 2004, 09:31:01 AM »
89 and newer large sami flanges are the same bolt pattern as the kick
