Ring and Pinion gears
  • 3225 Views
« on: July 08, 2009, 07:54:41 AM »
Hi can someone tell me the best place to buy ring and pinion gear sets for my 95 tracker. I want the lowest gears i can find. Thanks
Re: Ring and Pinion gears
« Reply #1 on: July 08, 2009, 02:52:27 PM »
The options are pretty limited. I believe that there is a company in Turkey that sells 5:83s. If you have an auto then you can use the gears from the manual (5:12s). 5:38s and 5:63s were fitted for very brief periods to particular models.
Offline cmays03
  • 99
« Reply #2 on: July 08, 2009, 06:39:16 PM »
what are you doing with the tracker? u have a few options. if you cant find anything lower than 5.13 then you can get a tcase reduction kit 4.24:1 I have it and 5.13 gears in the axles awesome low end but dont have any speed but i can do anything I want with it.
95 geo tracker sas with dana 30,35 axles 3.55 gears, 33 tsl's, 3 and 4 link suspension. stock motor trans, tcase has 4.24:1 reduction kit.
Offline zukimoo
  • 330
« Reply #3 on: July 08, 2009, 06:41:32 PM »
If you got the money get the t-case gears....it will give you a reduction on high range with lots on low range...this will make is possible to drive down the road at a good speed. I'm running 512 in the 413K and it can't go very fast.
06 Baja Buggy
Offline Armour
  • 360
« Reply #4 on: July 08, 2009, 08:21:54 PM »
T case gears for a trackick don't give you high range reduction! Only low range. But they do have a reduction box available now. Just not very cheap!
Offline zukimoo
  • 330
« Reply #5 on: July 08, 2009, 09:58:17 PM »
Driving around very slow gets real old fast....when I drive the Lj it's so slow to get around and the 413K is just as slow. You end up getting there and it's only a few minutes more but it looks so slow when you are getting around at 70km/h.
I'm going to spend the money on some mild t-case gears and then swap to 462's. I want highway and slow speed in the trails. We don't have rocks here so it's not an issue.
06 Baja Buggy
« Reply #6 on: July 09, 2009, 08:05:15 AM »
I just listed some 5.38 and 5.62 complete thirds in the for sale section.  They will bolt right in and lower both high and low range.
