Quick exhaust help, please
  • 11 Replies
  • 3158 Views
Offline essjay
  • 133
« on: July 09, 2009, 07:09:02 AM »
did a search for flange bolt, found nothing helpful.
I am "replacing" my stock exhaust, but I cant get the damn manifold flange bolts off, they are the bolts with springs in them, that connect manifold to pipe.  I have a rachet with a 2.5ft cheater pipe on it, and I put all I got in it. they wont budge, I honestly cant believe they havent broken!
im stuck like chuck.
Thanks for any help.
Offline Merlin93
Re: Quick exhaust help, please
« Reply #1 on: July 09, 2009, 08:20:05 AM »
I recently paid the mechanic for this, using his impact tools, having had a lot of difficulty with this on an MG-A in the 60's.
Three thoughts come to mind:
1) Heat the nut to red-freakin' hot with a torch and try again before it cools completely; repeat.
2) Soak the threads in penetrating oil overnight and try again.
3) Use a nut splitter and sacrifice the nut.
Harbor Freight Item #66547 shown ($4).
edit: Female threads are in the exhaust manifold flange, not a separate nut.
« Last Edit: July 09, 2009, 10:12:39 AM by Merlin93 »
Offline essjay
  • 133
« Reply #2 on: July 09, 2009, 08:34:54 AM »
Thanks for your help, where can I get new ones, would they be carried at a regular part store?
I prob have to call around, I am at my dads house in bfe
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #3 on: July 09, 2009, 09:51:43 AM »
Your parts store may have some generic ones that are close enough to work; but the exact replacements will be an item you need to order from a suzuki dealership.
I have always had good luck by repeatedly soaking the threads in penetrating oil for a few days (soak both the top and the bottom of the threads).  Then when it comes time to remove the bolt, use a torch (propane might help a little, but really doesn't get hot enough to heat the big chunk of cast iron rapidly enough to be really effective so oxy-acetylene is the way to go).  Try to direct the heat to the area around the bolt, and not the bolt itself.  This will expand the threaded area around the bolt and help to free it.
My rig is a fusion of Jazz and Funk; I call it JUNK
« Reply #4 on: July 09, 2009, 09:51:50 AM »
I just replaced with a generic nut & bolt replacement from local parts store.
Offline sammypro.com
  • 153
« Reply #5 on: July 09, 2009, 10:06:12 AM »
X2 FOR LOCAL PARTS STORE,HEAT, AND PENNY OIL!
Offline Merlin93
« Reply #6 on: July 09, 2009, 10:06:43 AM »
First, let me say I was mistaken about nuts. The bolt threads into the exhaust manifold flange, not a nut.  If at all possible, be real careful not to break the bolt, or you will have a devil of a time getting the broken bolt piece out. There's not much to heat here, 'cause the exhaust manifold will suck all your torch heat away very quickly. You'd need a major-league torch.  Start with the penetrating oil and let it sit for as many hours as you can. An impact wrench from below is probably your best bet for breaking it loose, or breaking it completely, if you try too hard. If you do break the bolts, you'll probably have to drill out the exhaust manifold flange for a clearance hole and use a longer through-bolt and a nut, a PITA.   This is not a high-strength application, so a high-strength Grade-8 style bolt is NOT required. I prefer to keep my Zuk all-Metric, so I only have to carry a limited set of Metric tools.  If you can find stainless, I would think that it would be less likely to rust in place. Be sure to use anti-seize with stainless, as it tends to gall.
I found http://www.mmsacc-stainless.com/metric/metric_prod.htm
on the Internet, but have yet to order from them. I'm waiting to put together a big order all at once. I'll add replacement exhaust down-pipe bolts to the growing list.
When you do put it back together, a little anti-seize on the threads will make it easier to get apart. The graphite-ed gasket at the manifold-to-down-pipe joint is often bad (mine was).  Plan on replacing it.
« Last Edit: July 09, 2009, 10:44:35 AM by Merlin93 »
Offline essjay
  • 133
« Reply #7 on: July 09, 2009, 10:43:28 AM »
yeah new gasken actually came with my cat convertor, I got a maremont cat and maremont superC muffler, so far, they seem like quality, I never saw a better muffler seem.
I am just soaking the crap out of them, one of them broke loose. Its a rainy day, got some coffee, lazy repair job.
« Reply #8 on: July 09, 2009, 11:17:38 AM »
Try PB Blaster for your penetrating oil. I think that stuff works great. Soaked all the stock suspension bolts on mine and they came off super easy.
Offline essjay
  • 133
« Reply #9 on: July 09, 2009, 11:24:34 AM »
AHH HAA.......VICTORY!!!!
yeah ob works better than wd, but wd is what I got here.
now I can actually do something.
Offline essjay
  • 133
« Reply #10 on: July 09, 2009, 02:28:18 PM »
WOW, thats what a sammi sounds like with exhaust, I can hear myself think now.
Thanks for your help fellas.
« Reply #11 on: July 09, 2009, 04:12:00 PM »
I remember when my donut between down pipe & exhaust blew out... man what an attention getter!
