Got my body lift from RRO today
  • 20 Replies
  • 7517 Views
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« on: August 06, 2004, 03:28:27 PM »
It was shipped exactly when they said and was very good quality but the instructions leave a lot to be desired. I used Heather's Budget Lift write up for most of the install. Thanks Heather.
Offline explosivo
  • 3157
Re: Got my body lift from RRO today
« Reply #1 on: August 06, 2004, 04:12:44 PM »
I shouldn't even have to say this, but PICS!!! :P
omghi2.us[/url]
« Reply #2 on: August 06, 2004, 05:06:31 PM »
;D
Offline jerryp58
  • 449
« Reply #3 on: August 06, 2004, 11:38:31 PM »
So...
How long to install?
What do you think of the results?
Jerry
Offline TN_Tracker
  • 1113
« Reply #4 on: August 07, 2004, 02:38:31 AM »
Yeah, I know, without pics it never happened. ;D I'll try to get some today. It took us about 4 hours to do the majority of the work but we were going kind of slow and it could be done faster. The biggest issue is getting the bolts lined up to install the extended nut. I have a few things to finish today.
SpinalTap
« Reply #5 on: August 07, 2004, 05:56:11 AM »
I see a body lift coming my way fairly soon as well...looking forward to the pics dude!
Offline TN_Tracker
  • 1113
« Reply #6 on: August 07, 2004, 08:15:27 AM »
Well, I've got most everything done. My ancient digital camera is taking terrible pictures so I've only got a few. If anyone is interested in some close-up pics let me know and I'll borrow my brothers new camera when he gets back from vacation.
Don't think I'll be cutting my rear tires on the body anymore. :P
Nice side view :)
RRO decal ;)
My thoughts:
Installation was easy enough but their instructions leave a lot to be desired. Their "for show vehicle only" statement on the instruction sheet is laughable. Do yourself a favor and lengthen the TC Shifter, I straightened mine and it hits the Automatic Tranny Shifter when in 4Lo so that needs some attention. Although the instructions are pretty much none existent I think that it's a pretty good deal for $120.00 and I'd spend my money at RRO again. ;D
Offline jerryp58
  • 449
« Reply #7 on: August 07, 2004, 11:34:36 AM »
Is this http://home.att.net/~jerryp58/tracker/lift_kit.jpg pretty much the RRO kit?
Does the body sit right on those spacers?
I'm curious, why do they say "for show" only?  Has anyone had a problem with body lifts off road?
I would like to see some "dead on" pics of the front & rear "skinless" bumpers.
BTW, Looks Good.
Jerry
Offline explosivo
  • 3157
« Reply #8 on: August 07, 2004, 12:33:46 PM »
Probably a liability thing. :-/
Lookin' good, TN!
omghi2.us[/url]
Offline TN_Tracker
  • 1113
« Reply #9 on: August 07, 2004, 12:36:58 PM »
BTW, Looks Good.
The picture is very close to what I got. The spacer blocks are slightly different and I got 10 blocks, there's only 9 in your pic. I left the factory rubber mount on top of the blocks next to the body and the factory rubber mounts below the brackets on the frame.
The "for show vehicles only" is just legal mumbo-jumbo meant to release them from any harm if you crash and the body separates from the frame. It's really not that unusual, I just thought it was funny because of the way their lift is represented on their site. ;D
Here's a couple pre-lift pics of the front bumper but you can't see much because of my Hi-Lift. I don't have a pic of the back.
Offline TN_Tracker
  • 1113
« Reply #10 on: August 07, 2004, 12:41:20 PM »
Lookin' good, TN!
Thanks ;D
Offline snakeman
  • 274
  • Alrighty Then
    • Oregon Trail 4x4 Association
« Reply #11 on: August 07, 2004, 05:38:53 PM »
Does anyone know the dimesions on the blocks? outside diameter? hole diameter?
I pour polyurethane for a living, and could knock out the block portions in about an hour. Just would be greenish color instead of black.
Just curious for future reference.
Oregon Trail 4x4 Association - Eugene, Oregon
http://www.ot4x4.org/[/url] Come check us out if your in the Eugene / Springfield area!
87 Tin Top, 1.6 16v, 4.9, 4.62's w/ sidekick rear, TT YJ swap, custom snorkle.
Offline TN_Tracker
  • 1113
« Reply #12 on: August 08, 2004, 01:36:33 AM »
Wish you'd ask 2 days ago, I could easily get an outside diameter now but the inside hole would be tough to get. The blocks don't really look like anything special and could be off the shelf lift blocks, it's the fasteners that are unique and I'm sure they make up most of the kit's cost.
TN_T :)
Offline jagular7
  • 1026
  • Jagular7
« Reply #13 on: August 08, 2004, 04:09:04 PM »
Snakeman, is the polyurethane you pour become solid? Or is the density more like a hard rubber? Is it possible to cut the poly spacer in 2 pieces, then secure the pieces together with a set of bolts/nuts?
The 3rd generation models (Vitara) have 3" long center body studs. Since these are so long, if there is a 3" body lift spacer, the body stud would have to be raised nearly 3" above the frame mount to get enough space to place the lift block underneath. Taking out the rubber mount within the frame mount helps. So, 3" long stud lifted 3" above the frame mount is some 6"!!!
But if the body lift is 3", and the body lift came as 2 pieces, the body would only need to be lifted enough to get the pieces over the stud and secured via the bolts. Another thought of securing the 2 pieces, is a hose clamp, however, during an accident, there is great potential of the stud shearing the 2 pieces. Thus the bolts would work rather easily.
Got any ideas also?
Lenexa, KS
Offline Grandmaster
  • 43
« Reply #14 on: August 08, 2004, 05:59:41 PM »
The body lift directions do suck badly.
The majority of tim eis spent aligning the bolts like he said above.
I did mine in about 8 hours, figuring out how to get everything together. (Pics or cad drawing in the pics would of been useful)
I also went all out and raised my bumpers 2 inches because I want to keep it as clean and as stock as possible.
Here's a pic of it with the bumper brackets done correctly. (threaded new holes so bolts hook as best as possible) I have no pictures of the new bumper brackets although I can get some if you guys have a big interest in seeing them.
