best lift for some bigger meat
  • 9 Replies
  • 3058 Views
Offline Greddy0
« on: August 13, 2004, 06:06:46 AM »
I just inherited a 95 4door sidekick  ;D  and like to build a mild trail rig out of it.  Previous owner overheated so I'm gona need a new radiator.  ? about the lifts out there for the sidekicks... for a 2" lift what is the best/cheapest way?  searching the archieves, I assume rear would be spacers.  Front has 2 options, spacers or flip the mount, correct?  What is the easiest/cheapest way.  Looking to run some 235/75/15 AT.  Any sites for spacers?  Thanks all
95 Sidekick 4x4
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: best lift for some bigger meat
« Reply #1 on: August 13, 2004, 06:38:38 AM »
Offline keith
  • 1176
« Reply #2 on: August 13, 2004, 08:03:26 AM »
For a 235 you most likely do not need any lift.  I am running 235 MT retreads with no lift and no problems.
Offline Greddy0
« Reply #3 on: August 13, 2004, 09:09:49 AM »
thanks for the quick replies....  So what lift the the majority of people running on their sidekicks?  Tire size?  What about the different lift options?  Thanks
95 Sidekick 4x4
Offline explosivo
  • 3157
« Reply #4 on: August 13, 2004, 09:15:37 AM »
Calmini 6" combo lift + 33x13.50 TSL LTB's... oh wait, you said cheap :(
omghi2.us[/url]
Offline Greddy0
« Reply #5 on: August 13, 2004, 09:21:46 AM »
OK. OK.   :o  Let say lowest cost to lift my sidekick  ::)  Also don't want to run too large a tire to reduce an already under powered rig. :-X
95 Sidekick 4x4
Offline explosivo
  • 3157
« Reply #6 on: August 13, 2004, 09:24:42 AM »
Gearing can correct the effects of oversized tires.
omghi2.us[/url]
Offline TN_Tracker
  • 1113
« Reply #7 on: August 13, 2004, 12:09:11 PM »
If you want inexpensive and not have to fab much go with 235/75-15's, RRO Coil Spacers and RRO 2"body lift. That's what I'm running and it works fine. Here's what you achieve:
2" body lift = 2" obviously :)
1 1/8" coil spacers = 1 1/2" strange but true, at least on mine
235/75-15's = about an 1" of lift over the factory size tires, but this varies depending on brand
http://www.rocky-road.com/sidekick.html
Offline Grandmaster
  • 43
« Reply #8 on: August 13, 2004, 03:12:19 PM »
I run 2" body spacers, and 2 inch coil specers w/ the flipped strut mount.
Running 30" mud Terrain tires.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #9 on: August 15, 2004, 03:44:03 AM »
With a 4 Door... being heavier in the butt.. when I just ran 235's every time I came out of a parking lot onto the street, or went through a dip in the road, my rear tires would rub the fenderwells and I started losing tread.
:P
With just a 2" suspension lift (the Calmini one) I STILL bumped the tires against the fenderwells. It took a body lift to stop it from happening.
Heather
« Last Edit: August 15, 2004, 03:45:11 AM by hcgalvin »
Heather Galvin
