wider tyre
  • 1836 Views
Offline MBB77
  • 50
wider tyre
« on: July 19, 2009, 04:15:40 AM »
do you think that 285/60R16 or 295/50R16 can be fitted without any problems(off-road and on-road using)?
grand vitara 03 V6
koni suspensions
king springs
one inch rubber over king
Offline brotherjack
  • 40
  • Jesus is the answer
Re: wider tyre
« Reply #1 on: July 21, 2009, 02:02:39 PM »
285x60R16 = 29.5" tall by 11.5 wide if I'm not mistaken.   Considering how a 28.75x8.5 tire fits on mine (touches the frame, even with wider than stock backspacing), I would guess that they're gonna rub the frame REAL REAL bad if you don't get some serious wheel spacers.  And then once you space the wheels out far enough to keep them off the frame, you might need to hammer/sawzall a bit in the front fenderwells.
Could probably be done, but not a 'quick and easy' thing to do, I would think.
"...the truth will make you free." John 8:32
Offline MBB77
  • 50
Re: wider tyre
« Reply #2 on: August 06, 2009, 02:51:57 PM »
i'd like to buy a 3' lift kit but what do think about 235/75R16?
grand vitara 03 V6
koni suspensions
king springs
Offline bzzr2
  • 1011
Re: wider tyre
« Reply #3 on: August 07, 2009, 07:53:28 AM »
if you run a lot of sand go with the wider tire, those aren't tall if the numbers are correct, frame rub is no big deal, you learn when to stop turning.  if not in the sand why not stick with a 10.5 width..
09 taco reg cab short box 4x4
