Something wrong with my tranny?
  • 28 Replies
  • 5232 Views
Offline explosivo
  • 3157
« on: August 09, 2004, 04:00:01 PM »
The other day I put the stock tires back on (200 mile trip next week, don't wanna wear off the LTB's tread) and now my top speed is around 65mph |removethispart|@3500rpm... that seems really high to me. Is there something wrong here? How does the overdrive in the 5-spd manual work?
omghi2.us[/url]
Re: Something wrong with my tranny?
« Reply #1 on: August 09, 2004, 04:45:43 PM »
On the 3 speed Auto (1:1 final drive)
speed was 70|removethispart|@4000 on 235/75-15 Tires
Your 3500|removethispart|@65 sounds like you are in 4th
gear.  OD is just a final drive taller than
a 1:1 ratio like .89:1  or 89 hundreths of
a turn to 1 turn of the driveshaft
Offline explosivo
  • 3157
« Reply #2 on: August 09, 2004, 04:50:07 PM »
It's odd, because I am in fifth. :-/
It's not vaccume operated or something, is it?
omghi2.us[/url]
Offline idaholwb
  • 772
« Reply #3 on: August 09, 2004, 04:51:36 PM »
 RPM sounds about right to me.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline explosivo
  • 3157
« Reply #4 on: August 09, 2004, 04:52:58 PM »
Dammit, that's gay. >:( I'll just look into getting some taller tires/wheels for my 33" radials before I head out on my trip :-/
« Last Edit: August 09, 2004, 04:53:34 PM by explosivo »
omghi2.us[/url]
« Reply #5 on: August 09, 2004, 05:01:42 PM »
Did you change diff gears ??
Sure you didn't forget where
5th is with those big tires  ;)
« Last Edit: August 09, 2004, 05:03:06 PM by wildgoody »
Offline explosivo
  • 3157
« Reply #6 on: August 09, 2004, 05:06:24 PM »
I did occasionally use 5th... going down hills :o
Oh well... what are the tallest tires that a place like Walmart would sell that would fit stock wheels?
omghi2.us[/url]
« Reply #7 on: August 09, 2004, 05:10:09 PM »
Well I stuffed a Radial Swamper 33/12.5-15
onto a stock rim  ;D
It's my space saver spare ;)
« Last Edit: August 09, 2004, 05:11:34 PM by wildgoody »
« Reply #8 on: August 09, 2004, 05:13:09 PM »
No, unless it's a 5 speed auto ??? Didn't think those
were made
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #9 on: August 09, 2004, 06:05:11 PM »
Thats about right man. My tracker would turn 4grand at 70/75. You'll be okay ;D so are you off to GR?
Offline explosivo
  • 3157
« Reply #10 on: August 09, 2004, 06:19:01 PM »
Damn... poor little engine :(
Yep. Heading south monday :)
omghi2.us[/url]
« Reply #11 on: August 09, 2004, 09:13:28 PM »
I guess you must be used to bigger engines. Its about the norm for a 4 pot car engine and its well down from the red line ;D
« Reply #12 on: August 09, 2004, 11:04:18 PM »
Go ahead of time and they can order you any size you want. I priced 33x12.50 MTR's there (not stock but they will oder them 4 you. For a highway radial they will have 31-32 in stock
« Reply #13 on: August 09, 2004, 11:07:19 PM »
It can handle it. I run 200 miles at 80-85mph daily. That's holding the X-90 at 4500RPM for 1 hr 15 min each way.  ;D
Enjoy 5th gear on your trip ;)
Offline explosivo
  • 3157
« Reply #14 on: August 10, 2004, 06:33:27 AM »
Hrm... I never drove it too much stock, and when I did that was way back in the day... if it seems about right, then I'll worry about it a little less... :-/
omghi2.us[/url]
