Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
airbag light stays on after body lift
TNTracker
37
July 27, 2009, 06:30:58 PM »
After installing my 2 inch body lift on my 2001 Grand Vitara my airbag light stays on and the horn quit working. I checked all the wires during and after lifting and nothing stretched or kinked. Any suggestions?
Yankee-Tim
562
Re: airbag light stays on after body lift
July 28, 2009, 01:35:41 PM »
Something got whacked. The body lift alone wouldn't do this (mine is a 3" BL). Trace the wires.
BTW - did you check the fuses?
Trackerprts
106
2
Aiirbag
July 28, 2009, 04:47:23 PM »
Did your steering wheal get turned when you extended the shaft ?
the wire in there for the air bag is called the clock spring,
99 Tracker pieced together out of 3 cars. RR Body and suspension lift ,31 10.5r15
winch bumper,rock sliders
losidriver2003
79
Reply #3 on:
July 28, 2009, 05:48:43 PM »
you can get the clock spring by its self from the junk yard . i got mine for 16 bucks or from the dealer for 400 to 600 hundred they will only sell it complete turn signal wiper all that stuff. or try a vendor from here they always say hawk has it.
Joe
01 xl7 calmini susp rro body lift 225 75 16 tires
TNTracker
37
Reply #4 on:
July 29, 2009, 07:02:44 PM »
Is there any chance the airbag will go off by accident? If not i will leave it. I don't like the thought of being in the woods with an airbag, this is one thing i didn't like about my 96 Tracker.
losidriver2003
79
Reply #5 on:
July 29, 2009, 09:02:15 PM »
the horn wire should be hot so i guess theres a chance you can unplug the yellow wire from the steering column
