URGENT HELP NEEDED!!!!! CUTTING OUT VITARA!!!!!!
  • 3513 Views
Offline spanner
« on: July 28, 2009, 05:48:09 AM »
Re: URGENT HELP NEEDED!!!!! CUTTING OUT VITARA!!!!!!
« Reply #1 on: July 28, 2009, 02:26:18 PM »
M reg with injectors, I assume thats a 1994 with a 16V engine? Have you got a Check Engine Light showing? If not then start by checking the woodruff key that holds the bottom pulley in place. Then pull the spark plugs (you've replaced them right?) and check the colour of them.
Offline sir lance
  • 342
  • I love my XL-7
« Reply #2 on: July 28, 2009, 07:00:25 PM »
change your fuel filter.............
Offline essjay
  • 133
« Reply #3 on: July 28, 2009, 10:49:26 PM »
what you mean it keeps banging? that sounds pretty serious, please specify.  how many miles you got on the clock? whats the year and engine specs? love your name btw
« Last Edit: July 28, 2009, 10:51:25 PM by essjay »
Offline spanner
« Reply #4 on: July 30, 2009, 06:18:08 AM »
THANKS FOR YOUR REPLIES GUYS AN YES ITS A 1994 MODEL AN 16 VALVE AND I HAVE REPLACED THE FUEL FILTER I THINK WELL IVE REPLACED A FILTER WHICH WAS GIVING ME A PETROL LEAK AND THE BANGIN NOISE ISNT FROM THE ENGINE IT COMES OUT THE EXHAUST LIKE ITS STRUGGLING YOU WOULD HAVE TO HEAR IT TO UNDERSTAND ITS WEIRD IVE ONLY HAD IT 6MNTHS AN I LOVE IT SO AM VERY DISSAPOINTED THAT I CANT FIND OUT WHATS WRONG WITH IT SO WILL TRY OUT YOUR SUGGESTIONS AN WILL LET YOU KNOW THANKS FOR SUGGESTIONS BYE FOR NOW
Offline philc72
  • 65
« Reply #5 on: August 13, 2009, 04:27:29 PM »
have you checked the air filter or if theres any obstruction in the plumbing anywhere that could cause all of that not getting air
Offline idaholwb
  • 772
« Reply #6 on: August 23, 2009, 02:04:15 PM »
Pull your timing cover off and check your timing marks. See if they still are able to line up. If not, you need to replace your crank gear and possibly have your crank repaired. That would cause all of the above...
97 Sport
265/70-16s
2" lift
2.0 swap
