2wd to 4wd
  • 1832 Views
Offline Bfunk
  • 406
2wd to 4wd
« on: July 28, 2009, 10:32:45 AM »
So if I get a 2wd trackick, will the 4wd parts just bolt in ???  Thanks to anyone that helps.
Brian
Re: 2wd to 4wd
« Reply #1 on: July 28, 2009, 11:08:58 AM »
You will need the transmission, transfer case, and almost the entire front end assembly to swap to 4wd.  Unless you want to do a solid axle setup, then there are a couple ways of doing it.
What are your plans for the vehicle?
Offline nh
  • 17
Re: 2wd to 4wd
« Reply #2 on: July 28, 2009, 12:51:24 PM »
There is a bracket for the front diff that you'll need to weld on. It's fairly straight forward. I just finished doing the change but without a donor vehicle it could get expensive. You need the whole  front diff, (to the hubs), transfer case, both drive lines, the rear transmission support and the 2 wheel drives have shorter springs than the 4 ,(but I don't know if you MUST change the springs or not).
Re: 2wd to 4wd
« Reply #3 on: July 28, 2009, 02:28:22 PM »
I would say not, the Fatboy models over here were all 4wd but had lowering springs fitted.
