Transfer case oil?
  • 14 Replies
  • 6484 Views
Offline balance
  • GO COLTS!
    • www.gotmudd.com
Transfer case oil?
« on: August 11, 2004, 09:54:06 AM »
what kind would you suggest?
is there a how too page somewhere i havent been able to find one thus far. also here is a pic of my kick. Long time lurker first time poster.
Jeremy
2in spring spacer, 29in super swampers, bikini top mod, cb, and a kick ass stereo system. 2300.00 invested. Not bad at all.
91 Sidekick
2" spring spacer lift
29" Superswampers TSL
More to come...................
http://www.youtube.com/user/GotmuddHaspin
Offline Cwkick
  • 888
Re: Transfer case oil?
« Reply #1 on: August 11, 2004, 09:56:54 AM »
The FSM for a 97 says 75W-90 synthetic.
I used plain dyno oil.  I changed it before I got the manual.   ;D
Cwkick
Offline balance
  • GO COLTS!
    • www.gotmudd.com
« Reply #2 on: August 11, 2004, 10:00:17 AM »
mine is a 94 think it will make a diffrence. i have one of them oil pumps to take out the oil how much and how would you recomend puting it back in?
91 Sidekick
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: August 11, 2004, 10:16:05 AM »
I use Castrol gear oil...I forget which weight...
Nice rims, those are from a newer Tracker aren't they?
Offline MB
  • 223
« Reply #4 on: August 11, 2004, 10:38:27 AM »
75w-90 is what the sammies call for to.
Refill till the gear lube runs back out the fill hole.
Good lookin Kick, glad you decided to quit lurking and Share!  ;D
Offline van7559
  • 145
  • I'll Leave Tracks All Over Your As$
« Reply #5 on: August 11, 2004, 10:38:53 AM »
What ever you do run synthetic I have heard it reduces friction more. Not sure it will make a noticable difference but it damn sure can't hurt to try.
95' Kick with a 3 in. body lift and plenty more to come!
Offline balance
  • GO COLTS!
    • www.gotmudd.com
« Reply #6 on: August 11, 2004, 10:55:59 AM »
yep they came with it, i only payed 1500 and it has a brand new engine all it needs now is rear shocks, i heard use the crown vic shocks. What year? also how hard is it to intall a new clutch and lockers?
thanks
91 Sidekick
Offline paps133
  • 166
  • make your own road..
« Reply #7 on: August 11, 2004, 11:52:40 AM »
the oil need in the tcase on a 1995 geo tracker is 80-90. depending the year it may very, i don't know. Just check it out in your owners manuel. Be sure to put the right stuff in, i'd go with dealer specs. hope it helps pierre
Offline jerryp58
  • 449
« Reply #8 on: August 11, 2004, 12:10:55 PM »
First of all, Welcome!
Second, I hate to throw an odd opinion (seems like I have a lot of them ::) ), but I thought I read somewhere that you should use crude in the tcase and diffs and synthetic in the auto trans (not sure about your manual).
I'm a fan of synthetic though so if I ever decide to spend the bucks, I may switch from the crude that's in there now to a synthetic in everything.
The only suggestion I'd make is to be sure you can remove the fill plugs before you remove the drain plugs.  I guess that's a no-brainer, but guess who drained the rear diff first and then found out he couldn't get the fill plug out (yup, me again :-[ ).  Let me tell you filling the diff through the drain hole was a major PITB.
Jerry
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #9 on: August 11, 2004, 12:44:51 PM »
the Tracker take synthetic GL4 and the sidekick take dyno GL4.  i have syn GL4 in my Transfer case.  ;D
« Last Edit: August 11, 2004, 12:45:23 PM by safarikick »
Offline balance
  • GO COLTS!
    • www.gotmudd.com
« Reply #10 on: August 11, 2004, 01:33:48 PM »
thanks for all the info guys,
;D
91 Sidekick
Offline track_this
  • 332
« Reply #11 on: August 11, 2004, 05:32:21 PM »
i used lucas gear oil 80-90 worked real good. as for the crown vic shocks use 1998 thats what i did worked good.
shane
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
« Reply #12 on: August 11, 2004, 06:05:37 PM »
Crown Vic shocks are for use with 3"
rear spring spacers or 3" lifted springs
but they should be fine if you got 2"
lifted rears
« Last Edit: August 11, 2004, 06:07:02 PM by wildgoody »
Offline trackermad
  • 150
« Reply #13 on: August 12, 2004, 12:38:10 AM »
Next time pull the transfer lever and fill from there its much easier.  That trick doesnt work with the trannie though.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline brace
  • 264
  • I built it; I break it; I fix it.
« Reply #14 on: August 12, 2004, 01:14:01 AM »
I just replace my tranny and the guys at Hawk said to us synthetic, so I did.  It was 12 bucks at autozone for the 2.7 pints.
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
