Gen2 Tracker fuel consumption
  • 12 Replies
  • 3569 Views
Offline jzap
  • 515
  • How difficult can it be?
« on: July 31, 2009, 09:53:21 PM »
In my old '96 2dr 5spd, I can coax about 28 to 29 MPG with the tires pumped up to 32psi.
I am considering a Gen2 Tracker (4cyl, automatic, 4WD), box stock, for a DD.  The EPA site shows the '96 at 24 and the '03 at 21.
I would appreciate some input as to the real world experience with this truck?  I have seen claims of 29-30 out of the Gen2.  Is this realistic?
Jim Z.
66 Apache camper
Offline Carnage
  • 2453
Re: Gen2 Tracker fuel consumption
« Reply #1 on: July 31, 2009, 11:35:01 PM »
Ive looked extensively into this and Ive found absolutely no claims of 28mpg+
Maybe if you used hypermiler techniques...
Offline trackinstile
  • 435
« Reply #2 on: August 02, 2009, 06:37:45 AM »
My 2000 2.0  with a stick gets about 25 to 26 usually, back country roads going 45 to 50 mph. hth.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: August 03, 2009, 02:38:12 PM »
I had a SWB '96 5-speed.  Got 29-30 mpg regularly, 28 if I really abused it.  29" tires knocked it down to 27mpg tops, corrected.
Then got a 2003 SWB 5-speed new.  Best it got on stock tires was 27 mpg.  29" tires knocked it down to 24 tops, corrected.
Then I put the 2.7 V6 w/ autmatic in it.  21 mpg tops, usually 19-20 (although 85mph into a strong headwind netted me about 14..).  29" tires only seemed to knock 1-2 mpg off, corrected.
I believe anyone telling you 28-30mpg for the Gen II is on crack, although I can only speak for the 2.0, not the 1.6 (I think it was available in '99?).
« Last Edit: August 03, 2009, 02:40:31 PM by beercheck »
XL-7 front coils
1.5" rear coil spacers
Offline jzap
  • 515
« Reply #4 on: August 03, 2009, 07:34:37 PM »
Thank you, guys.  That's all I needed to know to convince me to buy a Pontiac Vibe for my DD (EPA 30-36).
Don't Worry, the "96 Tracker is still in the driveway.  I can't use it for work, because of my computer and other tools of the trade that can't be left for even a few minutes in a vehicle that zips instead of locks.  So, its been "retired to recreational use". (fun fun!!)
Jim Z.
66 Apache camper
Offline bzzr2
  • 1011
« Reply #5 on: August 04, 2009, 10:56:54 AM »
i consume 11-13 litres per 100km on mine with 4.5inches of lift and heavy ssr's..
09 taco reg cab short box 4x4
Offline keith
  • 1176
« Reply #6 on: August 07, 2009, 06:33:23 AM »
Don't do it.  Don't give in to the darkside (Toyota)!  I briefly owned 2 Gen 2 and they both got 25 mpg in my Chicagoland commute.  With the rear divider panel in place behind the seats you can relatively securely lock up computer stuff.
Offline Carnage
  • 2453
« Reply #7 on: August 07, 2009, 04:15:35 PM »
there are tons of better mpg choices than a vibe
just say no
 8)
  • 435
« Reply #8 on: August 07, 2009, 04:24:17 PM »
Just got 26.15 mpg on the last tank
Offline jzap
  • 515
« Reply #9 on: August 07, 2009, 08:26:49 PM »
Its waaaaaay too late for that...  ...The black and red Vibe is replacing a boring beige Corolla (Prizm) that I have been driving for 4 years for work.  Got whacked from behind a couple weeks ago by a kid in a Mustang.
Would it help if I told you that the Vibe is a 5 spd (with cruise)?  It is getting a true 36MPG, which is about what I need to make out on the mileage allowance at work.
Jim Z.
66 Apache camper
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #10 on: August 08, 2009, 03:12:39 AM »
That's what I get with my liftef 4door on heavy 31" to.
A friend with a soft top tracker and same setup manages to get 9,5 litres per 100km, I can barely get that on stock tires....
Offline philc72
  • 65
« Reply #11 on: August 13, 2009, 04:30:05 PM »
wow I musta got a good one not many miles on it though and i dont drive very easy it gets beaten I have a four door 2002 w cold air intake and get about 31 mpg or 8-9 l per 100 4wd is another story though about 22 lol
Offline Carnage
  • 2453
« Reply #12 on: August 15, 2009, 01:02:17 AM »
i found someone who got 30 mpg in their 03 tracker (manual)
i was right, he used a few hypermiler techniques
