2002 tracker 4 door ?s
  • 2206 Views
Offline philc72
  • 65
« on: August 11, 2009, 08:13:28 PM »
Hey to everyone out there this is a wicked site with lots of tech info Has anyone heard of using tj spacers also do I need an alignment if I go up 1.5 to 2 inches and if so where do you get the camber adjust bolts Thanks .... Phil...
Re: 2002 tracker 4 door ?s
« Reply #1 on: August 12, 2009, 10:26:54 AM »
People have modified the TJ coil spacers in the past, but these days it's cheaper to just buy a set of coil spacers made for the Tracker.
You will need to adjust your camber a bit after installing the lift, the adjustment bolts can be bought at most part stores or just ordered on-line.  I think we share camber bolts with a VW Rabbit, but you would need to verify that.  If you plan on doing a lot of jumping/hard core wheeling you might want to use a welder to tack the adjustment bolt in place so it does not turn on hard landings.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: August 12, 2009, 03:26:53 PM »
Here is a lift kit that just became available in the US through Zuks Offroad:
http://www.zuksoffroad.net/upskirt.htm
Available as complete or partial as you want.
Ack
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: August 13, 2009, 02:12:49 PM »
I make a 2" coil spacers lift kit for your 2002. It will run you under $200 total. PM if interested
3" Masterkit1 body lift
Custom strut spacers
Offline philc72
  • 65
« Reply #4 on: August 13, 2009, 04:20:05 PM »
definately intetesterd what is pm lol i dont talk onlin3e much where r u located and could you tell me a total in cdn dollars with shipping Thanks....Phil....
Offline ack
  • 1659
    • Ack's FAQ
« Reply #5 on: August 14, 2009, 12:16:55 PM »
Click on jeff1997 in the upper left side of his post - above.  This will get you to where you can send him a Personal Message (PM).  That way you don't have to expose sensitive info. like address, phone number, etc. to everyone on the Internet.
I hope that this helps!
Ack
