Need new front coils.
  • 11 Replies
  • 3063 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: August 04, 2004, 05:18:50 AM »
dealer wants $260, only aftermarket is 1.5 lift for 400.   I just want stock -cheap springs.  Where to get them?
Re: Need new front coils.
« Reply #1 on: August 04, 2004, 05:40:03 AM »
I know you'll be shocked for mr to say this ::) Give Hawk a call (1-888-SAMURAI) ;D
I think I still have my Kick coils but they were used for +150K miles before I got my 3" kit so there kind of worn out. Let me know if you want me to see if they are still in the shop.
Offline jagular7
  • 1026
  • Jagular7
« Reply #2 on: August 04, 2004, 06:47:10 AM »
Not to take anything away from our supporting sponsors, but try http://www.car-part.com
Lenexa, KS
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #3 on: August 04, 2004, 11:49:23 AM »
Whats wrong with your coils? What are you trying to achive? Have you tried a local salvage yard?
Mike
Offline Bfunk
  • 406
« Reply #4 on: August 05, 2004, 03:39:37 AM »
I still have my stock ones also.  The rears are spoken for but I could part with the fronts.
Brian
« Reply #5 on: August 05, 2004, 01:52:12 PM »
Just call Hawks, I'm sure they
will give you a smokin deal on
some stock springs
Offline bandit86
  • 1641
  • elv8rguy
« Reply #6 on: August 07, 2004, 02:26:22 AM »
anybody try a spring out of another vehicle?
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #7 on: August 07, 2004, 07:36:16 AM »
Yes,  Cherokee and TJ are too soft to be used up front.  The a-arm acts as a leaver increasing the weight rate.
I have some pictures here some where.  And I have coil tag #'s too if ya need them.
I'm looking into Explorer / Ranger stuff next.
Spider Trax has a nice selection of New 5" dia. coils in the height and rate of your choice for $47 each.
« Last Edit: August 07, 2004, 07:36:42 AM by whitfield »
Offline bandit86
  • 1641
  • elv8rguy
« Reply #8 on: August 07, 2004, 07:39:58 AM »
i have xj coils. I thought it might be too wide, causing the shaft to hit it?
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #9 on: August 08, 2004, 03:54:26 AM »
Here is a clip with pics form my 4-door build up.  It might give you an ideia of how the Jeep coils look in place on the Kick.  May be some ZJ V-8 coils would work.  I'll have to try to get the #'s or score a set to try.
Jeep Tj Coils compared to GV 4-door coils  4.25" longer (But smaller Dia wire with similar # of wraps...   Hmmm ???  :-\\\\ )
TJ coils inplace of the GV ones...
Desired 4-dr ride hight / stance.  Ok maybe not quite that high (tires are off of the ground), But close...   [naughty]
But once down off of the Jack stands ...  THe coils compress to the bump stops.   [crying] [crying] [crying]   THe A-Arms act as a leaver requiring a much greater spring rate.
The coils do hit the edges of the struts but not enough to matter at this stage of trial and error.
« Last Edit: August 08, 2004, 03:56:13 AM by whitfield »
Offline bandit86
  • 1641
  • elv8rguy
« Reply #10 on: August 08, 2004, 11:54:55 AM »
A "shop" once told me firebird front strus fork in trackers to lower them.   Why not to raise them?  I would have thought it would give you more articulation because of the longer strut travel - 1inch?
« Reply #11 on: August 08, 2004, 12:29:03 PM »
The inner CV can't take more than
25* angle and I think that's maxed
out, more than that and you will nade
it.
I think the longer strut from a FireBird
will be too much, unless you can eliminate
the 3" strut spacer, it might work if it's
a close match
