rear upper control arm
  • 2554 Views
« on: August 29, 2009, 01:49:33 PM »
I did a 2 in spacer lift in the rear of my 4 door kick today and I dont like the angle of the balljoint on the upper control arm. Are there any aftermarket ones like the calimini vbar? with a heim? I dont really want just a spacer since its preatty rusty already
Re: rear upper control arm
« Reply #1 on: August 29, 2009, 03:20:43 PM »
I don't think there are any available outside the kits from Calmini and ZOR.
« Reply #2 on: August 29, 2009, 08:44:33 PM »
hm Guess Ill make my own
« Reply #3 on: August 29, 2009, 09:04:47 PM »
well Who makes the spacers i guess I can get one and make it work for a while
« Reply #4 on: August 30, 2009, 05:17:11 AM »
Mudchild if your in Canada, ZOR if your US.
Offline idaholwb
  • 772
« Reply #5 on: August 30, 2009, 05:37:39 PM »
Zukination in Canada makes a really nice rear control arm setup for like $500 for all 3 rear arms with Johnny Joint style joints... And they are all adjustable...
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Armour
  • 360
« Reply #6 on: August 30, 2009, 07:16:52 PM »
Just fab your own. I just cut the ball joint end off mine and welded on a plate and nut and screwed on a heim! gives me some adjustment.
Offline jeff1997
  • 1228
  • 27
« Reply #7 on: September 01, 2009, 03:09:49 PM »
I make a 2" spacer that the bolts go all the way through. It will run you $40 to the US or $50 to Canada.
3" Masterkit1 body lift
Custom strut spacers
