Engine Problem (Help!!)
  • 2811 Views
Offline ZukkinMad
  • 57
  • Whatcha Waiting For?
« on: August 06, 2004, 11:02:13 AM »
Hey Guys,
I have a problem under the hood. I'm hearing exhaust noises on the opposite side of the engine from where the header is located. A guy told me that it may be a welch plug gone bad, he said the 1.6L suzuki engines were plagued with this problem. Unfortunately he wasn't able to tell me exactly what the welch plug is and where on the engine is it located. The sounds seem to be coming from behind the intake manifold close to the firewall.
I'd like to get this prob sorted as it has my zuk sounding like a heep   ;D Could the welch plug be an EGR valve?
Zukk
1994 4dr Kick, Calmini 2' suspensin lift, RRO Coil Spacers front & rear, 2" RRO Body Lift, Super Swampers TSL SX, 15 x 8 black rims, calmini header, dynomax super turbo muffler & accel super coi
Offline jerryp58
  • 449
Re: Engine Problem (Help!!)
« Reply #1 on: August 06, 2004, 02:32:34 PM »
I had to do a Google on "Welch Plug", I had never heard of that one before :-/
The most common reference on Google says, Welch Plug = Freeze Plug.
I'm not sure what a freeze plug can do but leak or completely come out and dump all of the coolant.
What exactly do you mean by exhaust noises?
How's it idling?
Could it be an intake manifold gasket or a head gasket?
Jerry
« Reply #2 on: August 06, 2004, 02:36:13 PM »
There is an EGR passage that goes
through the head and into the intake
manifold, I don't know what a Welch
plug is, sounds like a muffler bearing,
you might not what to use that guy
for your repairs, for a fix, try to tighten
the intake nuts/bolts in the back where
the EGR comes through,  and Plagued ???
I don't think I've ever heard of this problem
Offline ZukkinMad
  • 57
« Reply #3 on: August 06, 2004, 03:26:01 PM »
How's it idling?
The noises are like if you loosened your header gasket, only thing the noise is coming from the opposite side of the engine. Had my exhaust system checked out today and it was ok. It idles very rough, and occasionaly hestiates on move off.
Offline ZukkinMad
  • 57
« Reply #4 on: August 06, 2004, 03:29:46 PM »
:) I think i mispelt the welch, its actually welsh. I'll try tightening the nuts in the back in the morning if my hands can fit behind there. Apparently the plaque only affected the 1.6L engines destined for 3rd world countries, in particular (The Caribbean)
Zukk
Offline jerryp58
  • 449
« Reply #5 on: August 06, 2004, 11:50:31 PM »
I'd do a vacuum and compression check.
Jerry
Offline jerryp58
  • 449
« Reply #6 on: August 06, 2004, 11:58:27 PM »
You may want to Google this yourself (if you already haven't).  Welsh seems to pretty much equal Welch, which seems to refer to a plug for a hole, whether it be in a block, carburetor, gearbox, or whatever.
I've never looked for the freeze (Welch/Welsh) plugs in the block, let alone any on the head or throttle body.  It sounds very odd, but who knows.  I think I'll look at my '90 manual, and the car, a little closer later and see what I can find.
Jerry
« Reply #7 on: August 07, 2004, 02:46:15 AM »
Sounds like what we would call a core plug. One of those gone bad will definately dump your coolant but exhaust noises are a different problem.
