under hood light
  • 2120 Views
Offline gsherred
  • 112
under hood light
« on: August 31, 2009, 08:09:49 PM »
has any one put a light under their hood.  If so what kind of switch did you use?
02 ZR2 K&N filter driving lights in bumper body colored coil covers. Jeff's 2 inch spacer lift.
Re: under hood light
« Reply #1 on: September 01, 2009, 08:39:37 AM »
An alarm "pin" switch - it grounds the return from the light when the hood is lifted.
Offline Novadon
  • 205
  • South Carolina. USA
« Reply #2 on: September 01, 2009, 12:07:03 PM »
I saw the style that uses a mercury (tilt) switch available in the aftermarket some time ago. You may want to search for one of those type lamp assemblies. Open the hood, and they come on automatically. They were used as OE lights on some cars. EASY hook up too! :)  Mercury related items may be getting hard to find due to the hazard of mercury though.
A simple dash area mounted toggle switch would work too. Just tap into any "key on" power or off your running lights so that you don't inadvertently leave the light on (under the hood).  ;)
« Last Edit: September 01, 2009, 12:18:07 PM by Novadon »
03' Honda Odyssey
Offline Sn0vv
  • 143
    • Cardomain Profile
« Reply #3 on: September 06, 2009, 07:16:26 PM »
this idea is the way to go....when the hood is lifted the light goes on when the hood is shut the switch is compressed by your hood and shuts the light off..... Having a mercury related device under your hood of moving parts and temp changes is not suggested
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline eyb
  • 84
« Reply #4 on: September 08, 2009, 04:08:58 AM »
I own a 1987 Volvo that comes with an OE mercury ball micro switch. It also comes with a manual switch on its side, to switch to either auto or manual. It works fine and I don't see this as something of a hazard or anything.
« Reply #5 on: September 08, 2009, 05:09:38 AM »
I don't see a mercury switch as being a problem, but for a home brew job, pin switches are going to be way easier to pick up.
Offline eyb
  • 84
« Reply #6 on: September 08, 2009, 07:59:10 PM »
I agree with fordem, one advantage of using the ones from the old volvo's is the water resistant qualities inherent on the lens/housing.
