Erratic idle only in cool weather
  • 2734 Views
Offline keith
  • 1176
« on: August 06, 2004, 01:30:51 AM »
I thought my idle gremlins had gone away, but this morning was 50 degrees and the tracker had the old unsteady idle until it was warmed up fully.  It doesn't do this at all when the outside temp is 60 or higher.  Does this sound like a problem with the air temp sensor?  I replaced the coolant sensor last spring.
Re: Erratic idle only in cool weather
« Reply #1 on: August 06, 2004, 05:36:45 AM »
TBI or MPI?
Offline keith
  • 1176
« Reply #2 on: August 06, 2004, 06:10:24 AM »
TBI or MPI?
TBI
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: August 06, 2004, 09:32:21 AM »
My Sidekick has always sputtered in cold wheather but after about 5 minutes of warming up it runs as smooth as silk.
I think this problem is normal.
« Reply #4 on: August 06, 2004, 10:23:43 AM »
Thers a point at which the ECU switches to a different map IIRC it is determined by a number of factors of which the air temperature sensor is one. If I find my FSM soon I will have a look. You should be able to check the air temp sensor.
According to my notes the nominal resistance of the air temperature sensor is 2.9Kohms at 20C, which is 68F
« Last Edit: August 06, 2004, 10:26:23 AM by Rhinoman »
Offline jerryp58
  • 449
« Reply #5 on: August 06, 2004, 02:34:07 PM »
Keith, did you ever check the vacuum?
Jerry
Offline Mike71
  • 1449
« Reply #6 on: August 06, 2004, 03:22:11 PM »
maybe u have water in the gas tank??? or is it an everytime its cold it idles funny kinda deal
Offline keith
  • 1176
« Reply #7 on: August 06, 2004, 04:03:17 PM »
No, how do I go about checking the vacuum?
Offline jerryp58
  • 449
« Reply #8 on: August 07, 2004, 12:19:43 AM »
I haven't done it myself, but I think the manual shows hooking up a vacuum gauge/pump (maybe something you can borrow from a local auto parts store) to a couple of different vacuum lines and seeing what kind of vacuum you can draw & hold.
If you don't have access to a manual, I can try to scan the procedure from my '90 manual later.
I get the erratic idle occassionally too and this is something I've been wanting to do; it's just not at the top of my list yet ::)
Jerry
