Front doors shaking on highway
  • 19 Replies
  • 6793 Views
Offline nighthawk801
  • 51
  • Zuki Lover
    • ClubGM
« on: August 01, 2004, 08:25:27 PM »
Both of my Sidekicks suffer from this and it has gotten on my nerves a lot lately.
Basically whenever I'm going over 55 MPH or so the front doors shake a lot as air must be getting inbetween the door and the body frame or something, pushing the doors out. On windy days it seriously feels like the doors will just suddenly be ripped off the car.
What could be done about this? I've thought the ventshades things might work but then I realized they attach to the door, not the body, so they wouldn't prevent the air from getting in behind the door and shaking it. Does everyone else have the same problem? Anybody done anything to fix it?
Between this and the super disgustingly weak engines these things have, I really don't like driving on the freeway very much, which is the pits, because I otherwise love the little things!
90 Sidekick 2-dr w/ hardtop, 250k mi.
2-3" susp., 1.5" body, 4.4:1 low, ARB rear, onboard air.
http://www.clubgm.com/redzuki
89 Sidekick softtop Stock, 180k mi.
Offline jerryp58
  • 449
Re: Front doors shaking on highway
« Reply #1 on: August 01, 2004, 10:50:42 PM »
I believe what you're talking about happens with my '90, or at least it's something similar.
I would describe it as the doors getting pulled out though.  Like there's less air pressure outside the door than inside the cab and the top of the door pulls out (kinda like burping the old tupperware bowl :-/ )
I have the Ventishades on mine (which I like given the likelihood of thunderstorms in this area), but it still happens.  I don't know if it happens as much, but it does still happen.
Oh, I forgot to mention, mine only does it on the highway if there's a very heavy crosswind or if I'm going above 70 MPH and then, it's just every now & then.
Jerry
  • 51
  • Zuki Lover
    • ClubGM
« Reply #2 on: August 02, 2004, 06:54:41 AM »
Yeah, that sounds like what I'm trying to describe. And it's similar, usually only at 60 - 80 MPH (if I ever hit that speed, haha).
Anybody have a cure??
Offline explosivo
  • 3157
« Reply #3 on: August 02, 2004, 07:02:36 AM »
So... what's it like going 60 in a Tracker? :p ;D
I haven't had that problem in either of my Trackers (90 LSi and 91). :-/
omghi2.us[/url]
  • 51
  • Zuki Lover
    • ClubGM
« Reply #4 on: August 02, 2004, 07:12:48 AM »
Really? So the doors stay nice and stable and relatively quiet at highway speeds?
I wonder if something is loose or something...
BTW, what gearing do you have while running those huge tires? That must be insanely slow!
SpinalTap
« Reply #5 on: August 02, 2004, 07:25:06 AM »
My doors don't do that either and I run it on the hwy every day at 70-75mph.
Offline explosivo
  • 3157
« Reply #6 on: August 02, 2004, 07:28:50 AM »
Quiet? What's that? :P
My doors might do it now, since I can't hear anything over the radio, tires, and engine, but they didn't when I first bought it. They don't shimmy around at all, I know that much.
Stock gearing with 33x13.50's. It's actually pretty tolerable. Better than driving my Festiva :o ;D
omghi2.us[/url]
« Reply #7 on: August 02, 2004, 08:05:39 AM »
It's probably the hard top compared to soft tops. Watch your friends/family climbing in and out of the ride. Mine pull out a little at the top even with most of the air excaping through the soft top. It all began after a wheeling trip with rear seat passengers. I thought nothing about it at the time, but they were climbing out holding onto the top of the door to keep their balance. They must of been putting quite a bit of weight on them because ever since they have been bent out at the top a little. You may be ably to adjust a little of it out by adjusting the door latch to hold the door tighter to the frame.
Offline 99Trackerconv
  • 430
  • I love my Tracker
« Reply #8 on: August 02, 2004, 08:21:17 AM »
My 99 does it too. Its always on the highway doing 65+ that it does it. I have the hardtop on now and I don't remember it doing it with the soft top on.
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline explosivo
  • 3157
« Reply #9 on: August 02, 2004, 08:28:43 AM »
Yeah, that could be it ;)
Forgot to mention both mine are tintops :)
omghi2.us[/url]
Offline jerryp58
  • 449
« Reply #10 on: August 02, 2004, 10:41:27 AM »
Same (tin-top) here.
I thought these things had some kind of flow-thru ventillation.
I need to notice if it happens with the air control set to either internal or external.
Jerry
  • 51
  • Zuki Lover
    • ClubGM
« Reply #11 on: August 02, 2004, 12:14:11 PM »
I have a soft top and a removable hard top though. Happens on both of them just the same.
I may try adjusting the hinges or something then... I'm actually surprised that few of you have had this problem. Hmmm... Keep the replies coming :)
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #12 on: August 02, 2004, 12:30:19 PM »
Yeah...
mine does it too...
Hey, even with the SAS I can crank her up to 80!  :o
Heather
Heather Galvin
Offline Mike71
  • 1449
« Reply #13 on: August 02, 2004, 02:02:34 PM »
mine does it but it might have something to do with the thousands of hours with the 15s compressing the cabin
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #14 on: August 02, 2004, 02:04:36 PM »
I have a four door as well and the window used to do that to me... looked as if the wind would pull it right off. Surprisingly the ventshades will make a difference and will cut some of that wind down when going top speeds. The only other thing to do is to tighten where the window meets the top of the frame. I just put in some thin metal right at the top of the frame and it secures it much better and doesn't pull as much. The only thing though is sometimes when I roll up the window (p/w) it gets stuck and I have to push out the window a bit so it slides snugly. There is not much you can do about the door tugging from the wind, it's just a vacuum in that pocket of the vehicle when driving.
steveo
