Sammi leaf spring rates
  • 1918 Views
Offline LawDog
  • 531
    • Emerling Chevrolet
« on: June 06, 2005, 07:26:40 AM »
I couldn't find this anywhere in a forum search.  Does anyone know what the spring rates, front and rear, are for a Sammi, or where I might find that information??
Re: Sammi leaf spring rates
« Reply #1 on: June 06, 2005, 08:07:56 AM »
What ya trying ta do? I would look at the max weight carrying capacity of the rig and divide by four, I would guess about 650 lbs each for max weight.dry weight is about 2100 lbs for the rig. mine weights about 2800 fully loaded and there close to max.
« Last Edit: June 06, 2005, 08:10:13 AM by mrfuelish »
Offline LawDog
  • 531
« Reply #2 on: June 07, 2005, 04:42:20 AM »
Not looking for weight capacity as much as spring rate. How much lbs it takes to compress spring 1".  For ride/flex reasons.
« Reply #3 on: June 07, 2005, 08:33:54 AM »
are you looking at fronts and rears?  I run rears up front and the ride is alot better but still stiff, I get about 24" plus of articulation out of it between the front and the rear flexing with spoa and 33's with 2 " back space but the tire size helps more than the springs up front,I'm switching over to yj's soon.
