Tracker lift?
  • 30 Replies
  • 10511 Views
Offline Dillboytos95
  • 24
Re: Tracker lift?
« Reply #15 on: September 21, 2009, 06:09:04 PM »
Yea i could guess you are right but that is 1.5" coil spacer and i dont want to run a body lift! :-\
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
Offline MUD CHILD
  • 355
  • 9
Re: Tracker lift?
« Reply #16 on: September 21, 2009, 06:45:27 PM »
Sky's been around longer and makes better parts. Sky's has a sponsorship banner on this site.
I think you should at least see mt stuff before commenting. The reason I designed this kit is because NONE of the spacer lifts available were up to my standard. I've said it before and will again how many vehicles to you see rolling off the production line with plastic suspension components? You do on the other had see aluminum parts. BTW... the spring spacers are machined to accept the stock rubber spring isolator
Personally, I would never run a billet alum or metal spacer. metal on metal= random grinding noises offroad.
How does your suspension work in your truck? Do the springs have rubber at both ends. I'm sure it doesn't. How bad does it make "random grinding noises" off road?
I have the firs kit I built in my wife's sidekick. It has more that 20 000K on it since I built and installed it, and I can assure you it don't have any "grinding noises"
Just cause someone advertises on the site doesn't mean they make a better product!
BTW.. Low range off road also carry my lift and they advertise on this site
« Last Edit: September 21, 2009, 06:56:13 PM by MUD CHILD »
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline rds573
  • 17
Re: Tracker lift?
« Reply #17 on: September 21, 2009, 07:24:20 PM »
I have the exact same question but I have a 1999 tracker.  Is there a out there the same as this for 1999 and up?   I plan to put on 30x 9.5 tires.
thanks in advance for the help
  • 24
Re: Tracker lift?
« Reply #18 on: September 22, 2009, 10:45:39 AM »
I am a beginner at lifts and everything so when i get the spacers how hard is it to install? And also i was going to get it from ZOR i think im gonna get new shocks with it, does the kit include struts and shocks?
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
Offline Praise Him
  • 256
Re: Tracker lift?
« Reply #19 on: September 22, 2009, 07:34:43 PM »
The "Size" '' are all the same, The 1/2 inch is made up with shock strut spacers. Its funny how you say "I don't want to run a BL, 90% of people with trackers and kicks run BL's. There are not many "lift" options out there for IFS zuk's, Unless you want to but the Calmini 3" susp. But even than the guys that buy the Calmini 3" susp end up paying for the Calmini 3" BL.
It's not "un common" to run a BL on IFS zuk's, They are cheap and give you clearance. Search threw the "members rides" picture thread, You will see what i am talking about.
If you are planning on buying this http://www.zuksoffroad.net/upskirt.htm , Think again, Like i said before, Its all the same stuff, But that guy is  WAY OVER PRICED. Coil spacers and strut spacers are like $130 max.
Do what you want.
sammy/toy axles/locked/geared/cased/36's
Offline jeff1997
  • 1228
  • 27
Re: Tracker lift?
« Reply #20 on: September 23, 2009, 03:03:24 PM »
My lift consisting of: 2-1.5" coil and 2-1.5" strut spacers for the front and 2-2" coil spacers for the rear is $135 to the US or $145 to Canada. If you want the rear diff spacer with it it is $30 more. All you need are longer rear shocks. Let me know if you are interested.
3" Masterkit1 body lift
Custom strut spacers
Offline MUD CHILD
  • 355
  • 9
Re: Tracker lift?
« Reply #21 on: September 23, 2009, 09:19:12 PM »
Do what you want.
Not to sure when the last time you steped foot into a machine shop... or if you ever have! But check the cost to get the billet aluminum and the find out how much to turn them out on a CNC leathe. You will see the kit is NOT overpriced, never mind all the steel parts are tig welded and powder coated. These are not cheeply made kits. So that is Mearly your opinion and you know what they say about those...
  • 24
Re: Tracker lift?
« Reply #22 on: September 24, 2009, 10:38:19 AM »
Ya well i know that it is not uncommon to run BL but i simply dont want to. I MIGHT run a 1" BL, but BL's make it really top heavy and that i just not what i want to do, also the kit is not overpriced those parts look like high qualiity parts and i know not only the material is expesive but the skill and labor put into them makes weather the part is of good quality or not.
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
Offline jeff1997
  • 1228
  • 27
Re: Tracker lift?
« Reply #23 on: September 24, 2009, 07:10:59 PM »
I have to stick up for Mudchild here. He is right, the cost of making an all metal lift is not cheap. His prices are not that high judging from the work and material that goes into them. This is the EXACT reason mine are made from plastic. I have a shop with all the needed CNC tooling and materials but the cost is just too high. My main area of expertise is plastics and although the cost is still not free or even cheap, it is much cheaper than an all metal lift.
I do give you props on a nice looking and I'm sure good performing lift. It takes some hard work to make these things, as you know.
Offline Praise Him
  • 256
Re: Tracker lift?
« Reply #24 on: September 24, 2009, 09:41:35 PM »
Do what you want.
Get a LIFE dude. Stop trolling, Do you notice how i am not addressing you.
Stop acting like a little Douche.
Offline MUD CHILD
  • 355
  • 9
Re: Tracker lift?
« Reply #25 on: September 24, 2009, 09:43:19 PM »
Thanks Jeff!!!
Offline MUD CHILD
  • 355
  • 9
Re: Tracker lift?
« Reply #26 on: September 24, 2009, 09:48:17 PM »
Do what you want.
No to sure what you problem is, but clearly you have NOTHING IMPORTANT to add to this thread.
  • 24
Re: Tracker lift?
« Reply #27 on: September 24, 2009, 10:04:27 PM »
Well lets get back to the topic, Thanks for the advice guys!
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Tracker lift?
« Reply #28 on: September 26, 2009, 11:39:40 AM »
Here is a link to my old tracker build up.  It might help you decide what route you want to go.
http://zuknation.net/Zuknation/modules.php?name=Forums&file=viewtopic&t=1032
Offline Jookycola
  • 372
Re: Tracker lift?
« Reply #29 on: September 26, 2009, 04:27:57 PM »
Me personally...i hate body lifts.
I like my plastic bumpers, i'm just not a exposed metal and tube bumper kind of guy.  So to me a body lift is cheap alright, you get what you pay for.
100's of tutorials and how-to's over the years on here and not one that shows you how to make aftermarket bumper mounts after doing a budget body lift.  And i refuse to pay for the Calmini kit just to get those mounts.  I'm in the same opinion as the OP of this thread.  For just a little lift get spacers or springs.
Avoid body lifts, they don't technically lift your truck at all.  since the frame is in the exact same place as it is when stock, you gain no real ground clearance.  Even then if you then add a 2 inch suspension lift your frame is still only lifted 2 inches.  A body lift is a waste of time unless you're going to build a huge trail killer rig.
  [/url]
