Tracker Lsi looking to buy.
  • 1938 Views
Offline homer74
  • 193
« on: September 19, 2009, 10:32:54 AM »
What should I watch out for on the particular model of tracker anything special or different than the other trackicks? please let me know.
Re: Tracker Lsi looking to buy.
« Reply #1 on: September 19, 2009, 03:05:21 PM »
Standard rust spots, if possible get a compression check. Crawl underneath and see if the cross member is bent up, if so it is probably a sign of off-road use.  These things are pretty bullet proof unless the elements or poor care do a number on them.
See if the person has a record for when the timing belt was last changed.  If not I would recommend that as one of the first things you do.
Offline homer74
  • 193
« Reply #2 on: September 20, 2009, 05:36:39 AM »
Will do thanks Drone. Will do.
