strut spacers?
  • 2081 Views
Offline suzi1
strut spacers?
« on: September 20, 2009, 12:15:06 PM »
I have installed 4 1.5" coil spacers on my 4 door 93 sidekick with Crown Vic rear shocks and everything seems fine and dandy, but I have read that everyone is recommending flipping the front struts and/or installing strut spacers on the front. Is this necessary or am I good to go with what I have? I dont do any "wheeling" but drive a ton on deep sand (I have also chopped the top and welded in some roll bars for a great beach buggy) and lots of washboard. Should I be worried?
S1
Offline chrisvitarasport94
  • 228
Re: strut spacers?
« Reply #1 on: September 20, 2009, 01:08:32 PM »
you should do this to restore the droop availalbe in the strut; either flip, or buy & fit spacers
you will then need some camber bolts
also you are advised to get a spacer for the top of the rear diff rose joint
these 3 mods make a real difference and finish what you have started off well
you might want to consider bump stop extensions dependant on what tyres you are using, to avoid rubbing in the rear arches; not so much a problem in the front
if your off roading doesnt involve much articulation then you could do without these 4 mods, but the car will drive better for them
  • 228
Re: strut spacers?
« Reply #2 on: September 20, 2009, 01:11:55 PM »
here's the web site of our foremost UK manufacturer to show what you need
http://www.bits4vits.co.uk/store/index.php?act=viewCat&catId=1
Offline jeff1997
  • 1228
  • 27
Re: strut spacers?
« Reply #3 on: September 20, 2009, 04:21:03 PM »
I have both strut spacers and the resr diff spacer that was referred to. Contact me for more info.
3" Masterkit1 body lift
Custom strut spacers
Offline MUD CHILD
  • 355
  • 9
Re: strut spacers?
« Reply #4 on: September 21, 2009, 09:58:36 AM »
I make strut spacers and the rear diff spacer that you need to complete your lift. The parts I make are made out of steel, plasma cut, tig welded and then powder coated. Comes with hardware. Contact me for more info
THE BLACK PARTS ARE WHAT YOU NEED
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
