1992 4dr brake issue
  • 2444 Views
Offline RJkick
  • 634
« on: September 22, 2009, 12:11:11 PM »
When I get in and first start the truck the brake pedal goes all the way to the floor.  It still stops the truck and if you remember to pump the brakes the pedal is fine and the truck stops.  The system has been bled, master cylinder was changed about 6 months ago, dealer says it checks out fine
Everything works perfectly with the brakes except that first push
Any thoughts
Re: 1992 4dr brake issue
« Reply #1 on: September 22, 2009, 12:18:03 PM »
Sounds like theres a leak somewhere letting air get in, have you checked the rear slave cylinders and front caliper seals?
Offline RJkick
  • 634
« Reply #2 on: September 22, 2009, 02:47:09 PM »
I had Brake Masters check everything and they came up with nothing
They work perfectly so if there was a leak would it only be that first push of the pedal after it sits for 8 hours or more?
Offline captchee
  • 224
« Reply #3 on: September 25, 2009, 02:19:59 PM »
im wondering something here .
 when i did my swap from a 89 rear end to the 95  rear end . i found that up above the rear A fraim was  another  proportion type valve that apeared to be spring loaded . IE there was a spring that came down and attached to the A frame . the 95 did not have this .
  i assume that  this little vale is a safty type of break  that is activated by the spring , if the rear end over exstends .
 i wondering if you have this same system , if the spring was broke or missing if it would alow the  lever to  to move on start up ????
 just a thought
« Reply #4 on: September 25, 2009, 06:11:25 PM »
 just a thought
That spring loaded thing is a LSPV (load sensing proportioning valve).  It basically applies more or less rear brake pressure, depending on the load that is being carried.  I do not think that would have any affects on (or cause) the pedal going all the way to the floor after the vehicle has sat for several hours.
Offline captchee
  • 224
« Reply #5 on: September 26, 2009, 07:52:07 PM »
 good to know , thanks for the info . thought it just might be a place to look at .
 i do know there is a bleeder nipple on mine so ?
Offline RJkick
  • 634
« Reply #6 on: September 28, 2009, 12:24:28 PM »
I made them bench bleed the system, master cylinder out of the vehicle and then do each line, and it seems to be okay at this point.  We figure there must have been a bubble of air in the line somewhere
