1.8 bellhousing
  • 2596 Views
Offline zukimcf
    • mcfarland offroad
1.8 bellhousing
« on: September 24, 2009, 05:29:14 PM »
I have a 98 sidekick sport 1.8 auto , wanting to know if the bellhousings and flywheels are the same as a 1.6 trackick . Hoping to switch to a manual .
98 sidekick 4dr woods rig
88 sami
91 track 3" calmini bL
Re: 1.8 bellhousing
« Reply #1 on: September 24, 2009, 06:07:17 PM »
No, they are not.  Different bellhousing, different flywheel.
The 1.8 uses a hydraulic clutch, the 1.6 uses a cable.  Bellhousings are swappable though.
Offline zukimcf
    • mcfarland offroad
Re: 1.8 bellhousing
« Reply #2 on: September 25, 2009, 03:54:05 PM »
thank you !
88 sami
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: 1.8 bellhousing
« Reply #3 on: September 26, 2009, 07:24:52 AM »
...as in the 1.6/1.8 transmissions mount to either bellhousing because the bellhousing mounts are physically the same at the transmission end?
Followup question: Are the input shafts the same on a 1.8 transmission compared to the 1.6?  Could you use a 1.6 transmission even though the gear ratios might be slightly different without dissassembly and replacement of the input shaft?
Ack
Re: 1.8 bellhousing
« Reply #4 on: September 26, 2009, 07:28:03 AM »
Yes, the main part of the trannys are the same (including the input shafts), so you can interchange BHs.
  • 6598
  • 68
Re: 1.8 bellhousing
« Reply #5 on: September 28, 2009, 08:49:34 AM »
I have bolted together without modficiation a 1.8 engine to a 1.6 2wd transmission. This would tend to suggest that a 4wd transmission would bolt together as well. I used the stock 1.8 flywheel and clutch (mine donor was a manual tranny car). There are differences with pilot bearing size / input shaft and flywheel shape/thickness with the 2.0 engines.
Hope that helps.
