Engine Problems
  • 15 Replies
  • 4216 Views
Offline jawman
  • 406
  • 1234
Engine Problems
« on: September 27, 2009, 09:34:24 AM »
I just picked up another zuki. This one is a 95 Sidekick 4 door. It has over 200,000 miles on it. The problem is that it sputters, there is oil all over the whole engine, and there is oil in the water. I checked the compression and they were all right at 90 PSI, but I could not get to the third cylinder because of the intake. What do I do?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Engine Problems
« Reply #1 on: September 27, 2009, 10:50:56 AM »
90 psi is a tad low - it's amazing that it would even try to run at that compression.
I would yank the engine and rebuild it - or at least remove the head and see what's the deal with the headgasket.  Water and oil usually add up to a bad head gasket.
Rebuilding is something to consider - especially if you got that 'Kick for near nothing and everything else (body, interior) is in good shape.
I bought a '93 with a bad crank bolt for $500, put 1700 into an engine rebuild, removed and installed the engine myself and drove it for three years with no problems!  It's better than a car payment - especially if you can do a lot of the tedious simple work yourself!
Ack
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #2 on: September 27, 2009, 11:21:01 AM »
thanks for the info. I paid $700 for it and the paint is in good condition with two minor dings. It also has nice wheels too. It runs good when it is not sputtering. What should the compression be?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #3 on: September 27, 2009, 11:22:59 AM »
also I was talking to guy and he said the oil is all over because of the head gasket. could that be fact?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline captchee
  • 224
Re: Engine Problems
« Reply #4 on: September 28, 2009, 06:41:18 PM »
would exsplain low compression and the water in the oil . as to oil all over the engine .
 that could be a bad valave cover gasket , Dist  seal , front maine or cam seal , sear main seal .
 could also be a bad PCV valve  ring. thus it letting valve oil blow out
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #5 on: September 29, 2009, 11:59:28 AM »
There is also oil sitting on the top of the plugs
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: Engine Problems
« Reply #6 on: October 11, 2009, 05:52:02 PM »
Sounds like you need to clean that engine thouroughly to at least determine why it's blowing so much oil out of it. Compression on a healthy 16v of that vintage should be in the neighborhood of 180 to 190 per cylinder +- 1% variation between holes. yours sounds like it may be ready for an overhaul.
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #7 on: October 11, 2009, 07:32:02 PM »
what is the best degreaser to use? I have a lot of things to clean, but I never know what to clean with.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: Engine Problems
« Reply #8 on: October 12, 2009, 04:54:34 AM »
Try and use something bio degradable, not harmful to the enviornment. whatever you use it's going to leave a hellofa mess under your truck.
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #9 on: October 13, 2009, 10:27:30 PM »
I hear you there
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline sammypro.com
  • 153
Re: Engine Problems
« Reply #10 on: October 14, 2009, 08:05:19 AM »
Simple Green, full stength. BAD ASS stuff
Offline GSPKurt
Re: Engine Problems
« Reply #11 on: October 14, 2009, 05:25:36 PM »
+1...
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #12 on: October 14, 2009, 08:23:58 PM »
I have used it before, but it expensive in the small bottle. where is a place to get it that is cheap? maybe in bulk or something?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
  • 153
Re: Engine Problems
« Reply #13 on: October 15, 2009, 03:10:15 PM »
wal-mart gallon ,,,like $15
Offline jawman
  • 406
  • 1234
Re: Engine Problems
« Reply #14 on: October 15, 2009, 08:12:51 PM »
sweet now I just need the soap bottle for my pressure washer
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
