lift kit done
  • 2559 Views
Offline crgm101
  • 80
lift kit done
« on: September 27, 2009, 04:26:38 PM »
hey everyone just finished installing my R.R.O. spoa kit with 6 inch perches, 2 inch shackles and there ott stage 1 kit and had a question after install my rear end sits a inch lower than the front is this normal or can i correct this. also my springs got real stiff i feel allot more bumps than i used to and there them same springs. 87 Suzuki samurai 1.3Lt
Offline zukimoo
  • 330
Re: lift kit done
« Reply #1 on: September 27, 2009, 06:22:51 PM »
I've had to deal with the rear a little lower before and just got the spring pack re-arched to compensate. As for the stiffness....I've started to add a ply when SOA and re-arching the whole pack. This has given me great riding in every one I've done.
Some people have said that they will loose their arch in a short period of time but they are all holding up. We don't wheel rock here so the stress on the springs is not as bad.
06 Baja Buggy
Offline crgm101
  • 80
Re: lift kit done
« Reply #2 on: September 27, 2009, 08:14:39 PM »
i was under the impression that re arching would stiffen the ride because a worn out spring would be softer if not do you know the average price for a rearch
Offline zukimoo
  • 330
Re: lift kit done
« Reply #3 on: September 28, 2009, 06:00:15 PM »
when I do the lift I bring the 4 packs and they add a ply on each and arch the packs for around $180. I've had to get some re-arched a few times to get all 4 corners equal. They just tweaked them a little.
As for the harsh ride I've always found that a SOa made a softer ride but after putting on the 31/33 then I run a low pressure in the tires all the time. Around 18-20PSI. This will make a big difference. I find the zuke being light enough to take the low air and not worry about it. I don't do too much highway.
06 Baja Buggy
Offline dres0081
  • 73
Re: lift kit done
« Reply #4 on: September 30, 2009, 07:40:31 PM »
you could just do a add a leef to bring yourself up just a tad in the rear or a little bit longer shackle. As for the ride i would look into decent shocks and not run such a high tires pressure. As far as i have noticed in most vehicles i have had that were spring over it does make it a little bit more stiff.
88 1/2 sami,yj springs spoa, 33s
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: lift kit done
« Reply #5 on: October 01, 2009, 01:22:53 PM »
Yep, I just made longer shackles and the problem was fixed.  ;)
