hello neebie needing yj help
  • 2240 Views
Offline mickuk
« on: September 28, 2009, 11:21:15 AM »
hello i am new to the forum.
over the last few months i have been rebuilt my samurai(chassie up). i have got to the point i need help on a few things.
i have used yj springs with sky ml kit. i am useing stock axles with 33 inch tyres.spoa.
i am from the uk and not many people use yj springs due to the avilablity of them.
i am trying to set up the bump stops but dont no how much bend the springs will take so dont no how low to set them.?
my samurais i have in the past have been spoa with a torque bar. do i need a torque bar when useing yjs? (i have a 1.6 suzuki engine in it)?
i have also been reading a cut down dc toyota prop will work on the rear whats good for the front ?
thanks for any help
Offline mickuk
Re: hello neebie needing yj help
« Reply #1 on: September 30, 2009, 11:55:33 AM »
any one??   :(
Offline Amilla
  • 1076
« Reply #2 on: September 30, 2009, 10:19:06 PM »
Bump stops are there to save the spring from bending negative.  You set the bump stops so that they stop the spring when it goes flat.  I too have YJs on my samurai.  They are just stock height springs, 4 pack front, 5 pack rear.  I have about 3 to 3.5" up travel.
A track bar is a good thing to have when using leaf springs, definitely want to cut down on wheel hop. I would say go with one again.  I still suffer from hopping when i get on the throttle.
You can run Toyota CV drive shafts front and rear.  The best year(s) to get are the 84-85 front drive shaft, they have a 35 degree max operating angle.  The 85+ are only 25 degree or less operating angle.  But you can modify them to operate at 35 degrees.
Here's a link to a pretty good write up on had to do this.
http://www.4x4wire.com/toyota/tech/cvmod/
This is what I did to my front drive shaft, so far so good.  I do have a pretty nasty front pinion angle so the drive shaft does bind at full droop.
Another option for the front is an 89-94 V6 4Runner rear drive shaft, its a non CV drive shaft with a 42 degree operation angle.  I am thinking about going with this option, or at least try it out.
Hope that helps
Amilla
Offline mickuk
« Reply #3 on: October 01, 2009, 09:29:27 AM »
thanks for that  ;D ;D ;D ;D ;D
