Lift question
  • 14 Replies
  • 4029 Views
Offline jawman
  • 406
  • 1234
Lift question
« on: October 01, 2009, 08:43:41 AM »
I have been reading some of the topics on here about coil spacer lift kits for trackick and noticed The mud child makes his kit with aluminum coil spacers and Jeff1997 makes plastic spacers. my question is what spacer is going to last longer and not wear away? Also how is it a 2 inch lift if you are using 1.5 inch spacers?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: Lift question
« Reply #1 on: October 01, 2009, 01:19:29 PM »
I dont know about the alum ones but the poly ones I have had, and seen last years without much issues.
Offline jawman
  • 406
  • 1234
Re: Lift question
« Reply #2 on: October 01, 2009, 05:26:36 PM »
what is the best pair of shocks to use with the 2 inch lift?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline sir lance
  • 342
  • I love my XL-7
Re: Lift question
« Reply #3 on: October 01, 2009, 07:40:14 PM »
the 1.5 inch on a 2 inch lift is only for the front, 1.5 will give you 2 inches, but both kits come with 2 inches for the rear.
and either one will work just fine. its all personal preference.
same with shocks, lots of options
-lance
Offline jawman
  • 406
  • 1234
Re: Lift question
« Reply #4 on: October 01, 2009, 10:03:29 PM »
what is the most popular shock?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline mike5721947
  • 545
Re: Lift question
« Reply #5 on: October 01, 2009, 10:13:17 PM »
mid 90's crown vic or mid 90's (95) mustang. both rear shocks.
31" kumhos 3inchs of lift.
Re: Lift question
« Reply #6 on: October 02, 2009, 04:25:10 PM »
The plastic spacers probably lighter and less prone to corrosion, I don't know what aluminium MudChild uses but if its of good quality then any corrosion will be cosmetic. I doubt if either will wear away, the plastic Jeff uses is very hard and aluminium will work harden.
Offline jawman
  • 406
  • 1234
Re: Lift question
« Reply #7 on: October 03, 2009, 08:40:07 AM »
so stock crown vic shocks work with the lift. how about these doetsch tech shocks that are an option on the kit from ZOR?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline mike5721947
  • 545
Re: Lift question
« Reply #8 on: October 03, 2009, 09:33:06 AM »
they are better but the crown vic shocks are 15 bucks a shock... some people go with the higher end shocks ZOR sells, some go cheap. depends what you want to spend.
Offline jawman
  • 406
  • 1234
Re: Lift question
« Reply #9 on: October 05, 2009, 09:22:25 PM »
I don't have an endless budget, so crown Vic it is.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline MUD CHILD
  • 355
  • 9
Re: Lift question
« Reply #10 on: October 05, 2009, 11:41:02 PM »
The coil spacers in my kit are made from billet aluminum. They will not corrode, they'll out last the vehicle. As far as wear they don't wear the coil spacer is machined to accept the stock rubber spring isolator as you can see in the picture. This will also make sure there are no squeaks or rattles.
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline jawman
  • 406
  • 1234
Re: Lift question
« Reply #11 on: October 06, 2009, 10:50:42 AM »
I see. I know how to install it some what, but I don't know how long it takes to install it. Also I know with some kits there is a little bit of modifying to be done. Is that true with yours?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline MUD CHILD
  • 355
  • 9
Re: Lift question
« Reply #12 on: October 06, 2009, 11:44:17 AM »
You can easily install this kit in your driveway in 4-5 hours, or even quicker depending on how fast you work. There are no modifications that have to be done to install this kit. You will have to install camber adjusting bolts and get a front end alignment... but you have to do that with ant of the spacer lift kits available
Offline sir lance
  • 342
  • I love my XL-7
Re: Lift question
« Reply #13 on: October 06, 2009, 12:47:05 PM »
hey mud child, hows that bumper working out for you?  ;D
Offline MUD CHILD
  • 355
  • 9
Re: Lift question
« Reply #14 on: October 06, 2009, 09:12:23 PM »
Quite well bud, I removed the winch plate inset a receiver into it and added a couple tow points. Looks good on there. Good job on the build.
