secondary not opening
  • 2449 Views
« on: October 01, 2009, 07:21:33 PM »
any hits on how to troubleshoot subject, when i hold her wide open and look down her throat the secondary is not opening. when i shove a screwdriver down the throat, this baby will come alive. Ive gotta a lotta help from this site.
double thanks to all
Re: secondary not opening
« Reply #1 on: October 02, 2009, 06:55:45 AM »
What vehicle, what engine, what carb?
Some carbs the secondary is vacuum operated - the Aisin on my Swift works like this ...
The accelerator linkage that opens/closes the primary prevents the secondary from opening until the primary is fully opened, and will close the seconday when the primary closes - but the secondary will never open unless there is sufficient vacuum.
Check the linkage on the secondary throttle plate - make sure it's not binding (I've had this happen), and make sure that whatever portion of the primary linkage that blocks the secondary from opening to soon is functional.
« Reply #2 on: October 02, 2009, 08:01:42 PM »
sorry, 87 sammi, 1.3 stock, diahitsu vacuum secondary,
« Reply #3 on: October 05, 2009, 02:53:46 PM »
It won't open with the vehicle not moving, it needs load.
« Reply #4 on: October 05, 2009, 06:35:35 PM »
so much for doing a visual on this subject.
got a vac gage today, still hoping for end to carb saga
« Reply #5 on: October 07, 2009, 06:31:28 PM »
The secondary vacuum pot (sic) has two vacuum line connections. when I block either one and pull a vacuum on the other one, neither connection will hold a vacuum.  Should this hold a vacuum like the rest of the vacuum pots (like the one on the distributor)?
Also the little blue box in front of the secondary vacuum pot makes a ticking noise when the key is on, Is this normal?
It sounds like there is a vacuum leak somewhere, not sure.  Thanks for the help
