Sidekick Oil Leak
  • 4066 Views
Offline Looperman
Sidekick Oil Leak
« on: October 05, 2009, 11:26:02 AM »
I have a 1997 Sidekick. It has a little unit on the bottom front of the Oil Pan. It has electrical wiring to it. It is leaking. What is is called. I tried looking up Oil Sending Unit. It does not look like what I found on the internet. Where can I buy this unit.
Thanks
Looperman
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Sidekick Oil Leak
« Reply #1 on: October 07, 2009, 05:43:38 PM »
Acckording to the '96 Tracker FSM Project (available at Ack's FAQ - see link in signature below) The sensor you have described is the Crankshaft Position Sensor (CKP).  It sends pulses to the ECU indicating the engine RPM.
http://www.acksfaq.com/96-FSM-v2-6e3-c1-pdf.htm
An actual pictoral of it may be in the engine section itself.  Unfortunately links to all the sections have not been added to the search database so the next best thing for finding stuff is:
http://www.acksfaq.com/trackerfsm.htm
The leak is not from the sensor but from the oil pump seal, the front main seal or the oil pan.
I hope that this helps!
Ack
« Reply #2 on: October 07, 2009, 06:11:31 PM »
Exactly what Ack said.  If you have to replace that front seal you might as well swap out the timing belt at the same time since you have to remove it to replace the seal anyway.
When you swap it out you might want to do yourself a favor and just pull the radiator.  It gives you a lot more room to work with.  :)
