96 vs 95 Fuel Injector
  • 1786 Views
« on: October 05, 2009, 01:37:44 PM »
After doing my JDM swap an injector went bad (Yea, that was fun troubleshooting).  I tried swapping an injector from the JDM (a 95 or lower block) but it failed to function as well.  I noticed the design was a bit different, is there a difference between the 96 model year and older injectors for the Multi-Port injection based 16 valve engines?
Re: 96 vs 95 Fuel Injector
« Reply #1 on: October 05, 2009, 02:45:26 PM »
I would expect so, earlier models are batch fired not sequential so I would expect an earlier injector to have half the flow rate of a later injector. Are there any markings on the injectors?
« Reply #2 on: October 05, 2009, 06:46:30 PM »
No, just a different jet style setup and one is pink and the other has a white label.
The 96 has 4 small jets where the other motor had two large ones.  I don't have a manual for a pre-96 16 valve or I would check the specifications to see if there is a change.
Fun fact, the 96 is batch fire on start-up.  It will fire every time the crank position sensor goes off.  Once the engine starts it switches over to a batch mode.  Then to sequential once the engine starts to warm up.
« Reply #3 on: October 06, 2009, 12:31:05 PM »
Some of them also switch back to batch firing when you floor the throttle in order to get enough fuel enrichment.
