carb>?
  • 1501 Views
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
carb>?
« on: October 08, 2009, 02:45:03 PM »
So my samurai will run but usually when it kicks down to idle its rough. Also sometimes it seems normal then it will just die out of the blue be alittle tough to start. Then run good for a few minutes then rough, sometimes die again..
Right now it wont even start and the little window on the front of the carb looks empty of gas. I can suck it up pass the mech fuel pump all the way to the carb inlet. So I wonder if there is gunk in the fuel inlet? I took off the mech fuel pump and its easy to plung and wasnt leaking oil so I think its good.
thoughts? ideas?
Offline captchee
  • 224
Re: carb>?
« Reply #1 on: October 09, 2009, 06:22:24 AM »
