stuff in ebay???
  • 2310 Views
Offline lokomonkey
  • 41
stuff in ebay???
« on: August 02, 2004, 03:59:57 PM »
looking on ebay, I found this:"SUZUKI SIDEKICK Z1 PERFORMANCE MODULE 22HP KIT" and they claim to improve your performance 13-22.5hp, do you have any experience with this device?? is it real?? it only cost like 20 bucks!! please give me your 411, thanks
Offline explosivo
  • 3157
Re: stuff in ebay???
« Reply #1 on: August 02, 2004, 04:03:21 PM »
If it's what I'm thinking of, it's essentially a $20 resistor.
omghi2.us[/url]
Offline lokomonkey
  • 41
« Reply #2 on: August 02, 2004, 04:38:38 PM »
a resistor?? so does it works? what exactly does for the performance?
Offline explosivo
  • 3157
« Reply #3 on: August 02, 2004, 04:43:23 PM »
It does something to the sensor that takes the temperature of incoming air (I think) so that it thinks it's really cold, so it makes it run rich (I think), or something like that.
I should just wait for someone who knows for sure ;)
omghi2.us[/url]
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« Reply #4 on: August 02, 2004, 05:23:43 PM »
Just a chip upgrade.
Would not touch it.
The only way you have a chip upgrade is if they guarantee the power gains.
Example the person fitting the chip put your car on the dyno and shows you the figures than install the chip back on the dyno and he can show you the gains.
Really all a chip is going to do is lean it out, make it richer or change the power curve.
Just my two cents.
Dave
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Offline jerryp58
  • 449
« Reply #5 on: August 02, 2004, 10:55:22 PM »
Look at the feedback, you may get a clue there.
Back when they were charging $3 for this "chip upgrade", I figured I'd give it a shot.  I knew beforehand, from reading the feedback, that the "chip" was a simple resistor that could be purchased from Radio Shack for $0.30, but I figured I'd give it a shot.
I believe it went into the line for the intake air temp sensor.  It "fooled" the computer into thinking the air temp was cooler than it actually was.  As was said in another reply, this changed the fuel ratio and timing with the intent of making you feel like you had more HP.
I'd seen this technique used effectively on Trucks TV but it was with a much more sophisticated system.
If it was a few bucks, I'd say try it for yourself, but I can tell you that all it really did for mine was make it idle a little faster.  I felt NO power increase.
« Last Edit: August 03, 2004, 04:08:11 AM by jerryp58 »
Jerry
Offline lokomonkey
  • 41
« Reply #6 on: August 03, 2004, 02:35:40 AM »
WOW this forum is great! thanks guys this really helps. ;)
