Vent Visor (or other) side window shades
  • 1970 Views
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« on: October 13, 2009, 01:44:24 PM »
Referring to the plastic visors that allow you to keep your windows cracked in the rain....  I'm leaning toward putting on a set.
Which have you used?  Like 'em?  Is the purely stick-on style better/worse than the kind that stuff into the window slot?
XL-7 front coils
1.5" rear coil spacers
Offline Sn0vv
  • 143
    • Cardomain Profile
Re: Vent Visor (or other) side window shades
« Reply #1 on: October 14, 2009, 07:53:37 PM »
I have been having ALOT of trouble with the slide in type vent visors they work ok on the back doors (4 door model tracker) but the fronts tend to slip out causing the window not to shut properly........I ended up using a little bit a gorilla glue on the front trim which did the trick but if I were to do it again i would go with the stick ones...if done right they last forever...heck went to the junkyard today and there was a tracker with stick vent visors still attached even after all the abuse its taken.....
I bought the weather guard vent visors...(NFG)
2000 Cheverolet Tracker 2.0L 4cyl 5 door hardtop
with all options and 4x4 to top it off
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: October 15, 2009, 02:54:53 PM »
Thanks.  That's the sort of testimonial I was looking for.
XL-7 front coils
« Reply #3 on: October 16, 2009, 07:39:44 AM »
I put Ventishades stick on type on my 1999 Tracker 4dr. in 2003 and they are still there with no problems. They also eliminated the wind pounding in my face problem when I had the window fully open.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #4 on: October 16, 2009, 08:24:22 AM »
Excellent.  Thanks.  And welcome to the site.
XL-7 front coils
« Reply #5 on: October 16, 2009, 06:46:16 PM »
I used the stick on type on my Suzuki Swift - it was a dealer supplied SGP option - worked so well I'm looking for a set for my GV
