Need coolant hose for IAC
  • 1425 Views
Offline keith
  • 1176
« on: October 14, 2009, 05:49:13 AM »
I discovered a pinhole leak in one of the coolant hoses that goes to the idle air control. Is there a readily available type of hose I can substitute for this hose or would I be better off with the factory type hose? Where can the factory hose be readily obtained from?
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Need coolant hose for IAC
« Reply #1 on: October 17, 2009, 09:56:34 PM »
If you take the hose to the local auto parts store, they should be able to sell you a similarly-sized length of generic hose.
It won't have the custom bends in it but it'll work.
Or you can stop by your local Suzuki dealer.  I can't (nor probably will they) guarantee that they will be able to get you one or how long it will take...
I hope that this helps!
Ack
