rebuilding front samurai knuckles
  • 5769 Views
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« on: October 24, 2009, 10:24:05 AM »
Iam rebuilding the front knuckes got a killer kit from LowRangeOffRoad. Hears the proble i cant remember how i took the knuckle gasket off trying to find out how it goes back together. ( rubber, felt, bracket, and cover bracke? ) Please help.
Suzuzi:: Squeeze between the shit they cant crawl over
phloop
Re: rebuilding front samurai knuckles
« Reply #1 on: October 24, 2009, 11:31:51 AM »
Do a search on Ack's facts, he should have some info there.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #3 on: October 27, 2009, 04:54:37 PM »
Thanks for all the help frontend done and ridding good ;D
« Reply #4 on: October 27, 2009, 11:59:48 PM »
It's nice to not have oil dripping onto your tires after a run isn't it?  :D
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #5 on: October 30, 2009, 05:55:08 PM »
Yes it is very nice to have a good front end. I even went ahead and put my LockRight locker in (ok had someone else do it ).
I have to give LowRangeOffRoad a big thanks for getting me parts fast and the cheapest.............................................THANK YOU ALL!!!!!!!!!!!!!!!!!! ;D ;D ;D
Offline Travis Beebe
« Reply #6 on: October 27, 2010, 09:00:27 AM »
how much would you think this cost just a ruff guess any one..... and should you do both sides or only one
87 sami
4inch SPOA
31s
95 1.3 Camed
5 speed
« Reply #7 on: October 27, 2010, 12:59:25 PM »
Their are two kits available, a full rebuild kit or just the seals.  Normally you do both at once since they come in a two pack and your already tearing things apart.  :)
I like to low range as they have an easy to use web page, but most of the sponsors of Zukiworld.com carry the kits.  So you can give any of them a call.
http://www.lowrangeoffroad.com/suzuki/samurai/axles/front-knuckle-rebuild-kits.html
http://www.lowrangeoffroad.com/suzuki/samurai/axles/knuckle-seal-kit.html
Offline airmanwilliams
  • 913
« Reply #8 on: October 27, 2010, 01:32:30 PM »
the best way to go is like drone says do both sides at once since it will all be apart anyways an if you did just one side you dont want a problem soon with the otherside and have to tear it apart again. I just finished my front axle last weekend with the $145 kit from lowrange found a spare axle from a buddy rebuilt it when I had time and swapped it in when it was finally done. Now I just need to get an alignment done.
1993 4door Suzuki Sidekick JX
