water in oil...white smoke HELP ASAP
  • 10 Replies
  • 4258 Views
« on: October 25, 2009, 08:27:57 AM »
I swapped my 1.3L for a 1.6 8v in my sammy. I used the carb, intake, and exhaust manifold off the 1.3. Started up perfect. Drove it down the road and lots of white smoke. when i got back it was over flowing oil and water out of the dip stick tube. did i use parts that don't interchange? Did i put the intake gasket on wrong? This has been a year and I am SUPER exited to get it going so please help ASAP! I know maybe head gasket... cracked head...etc. Anything simple? I might just put the 1.3L head on it if I don't get it soon.
Jason
Offline sir lance
  • 342
  • I love my XL-7
Re: water in oil...white smoke HELP ASAP
« Reply #1 on: October 25, 2009, 09:07:22 AM »
sounds like a blown head gasket to me.
its not a hard or exspensive fix tho,
Offline locjaw
  • 2045
  • 22
« Reply #2 on: October 25, 2009, 09:31:08 AM »
looks like there is something internaly wrong with the motor. the 1.3 intake and exhaust should bolt up to a 1.6 8v just fine.
« Reply #3 on: October 25, 2009, 07:36:31 PM »
My dad thinks i might have put the intake gasket on wrong. Is there only 1 way to put it on? Last... Anyone have a picture of the intake side of the engine so I can make sure that the hoses are in the right places...
Offline captchee
  • 224
« Reply #4 on: October 25, 2009, 07:40:55 PM »
  im assuming the engine  was running before you did the swap  and not left set  over the winter and thus froze  and cracked a water passage
 did you have the head checked before you  put it on ?
 when you tourqed the head down , did you follow the  sugested patern ?
 with that much water  your dumping  coolent strait to a oil passage and to the cylinders .
 drain the  engine completely .
 pull the head off  and look at the gasket  you will be able to tell where the leak is crossing over at .
 take the head down to a mechine shop and have them check it  to make shur its not warpped .
 now someone else here with more knowlage on suzuki engines then I do  should be able to tell you  also about the head bolts . im not sure if suzuki does this or not . but i know chevy  on   a couple of their engines , have head bolts that  screw right into  coolent  passages . if you dont put on a sealing compund on those bolts , coolent will pump  right up into the  valve covers  and down into the  oil pan  .
 this will also act like a blow head gasket becouse the coolent  leack around the valves into the  cylinders
 sounds to me like you have  1 of4  things  happening or a combination of all 4
1)  cracked  coolent passage 3
2) warped head and thus a baddly blow head gasket
3)  the engine has a head bolt that goes into a coolent passage  and is not sealed . thus is leaking coolent  up onto the cam  down into the crank case  and  through the valve seals into the  cylinders
4) intake gasket   gasket leaking coolent into the intake .
 i wouldnt think that would be the case though as  with that much water  the engine should have  locked up
« Last Edit: October 25, 2009, 07:44:19 PM by captchee »
« Reply #5 on: October 31, 2009, 02:27:50 PM »
Has anyone put a 1.3 carb on a 1.6? I just went to buy a new gasket and they are quite a bit different. Not sure which one I should use...
« Reply #6 on: October 31, 2009, 03:35:07 PM »
The 1.3 intake will bolt up to a 1.6L 8 valve engine.
« Reply #7 on: November 01, 2009, 05:26:08 AM »
drone. what gasket do you use?
« Reply #8 on: November 01, 2009, 11:04:05 AM »
You will use the standard intake gasket for a 1.3L Samurai.  Just give you local auto parts store a call and they should either have one in stock or be able to order one next day.
« Reply #9 on: November 01, 2009, 05:06:53 PM »
sweet thanks. I put a 1.6L gasket on. that is probably why it was leaking....
« Reply #10 on: November 07, 2009, 06:20:33 AM »
Put the $3.99 1.3L gasket on and that fixed it! runs great now.
