ring and pinnion
  • 24 Replies
  • 5688 Views
Offline v-stone
  • 625
Re: ring and pinnion
« Reply #15 on: November 03, 2009, 08:55:03 PM »
will samurai gears fit in a tracker
You should be able to use samurai gears in the trackick rear too.  Just use the samurai carrier.
unless the the rare 1.3liter sidekick has the smaller bolt pattern than other sidekick/trackers the sami third will not fit in the rear, its a different bolt pattern and bolt size. I have both thirds sitting side by side in the garage and everything about the sidekick rear third is bigger. Are you saying you can blend them ??? ??? ???
The 1.3 sidekicks had the large rear thirds, just like any other trackick.
From what I remember, the distance between the carrier bearings are the same (or close enough) that you can use a samurai carrier in a trackick rear third.  The bearings are the same size, so there will not be any issue with the bearing caps.  And the pinion bearings are the same size too, so a samurai pinion will fit in a trackick rear third just fine.
Gotcha!
4 door kicks have 5.12
SAS Tracker! No looking back now.
« Reply #16 on: November 03, 2009, 08:55:08 PM »
what do the 4 door auto 16v kicks have
5.12s.
« Reply #17 on: November 03, 2009, 08:56:31 PM »
Gotcha!
I edited my last post, because I think I am wrong, so you might want to go back and read it.
Offline jeff5000
  • 37
« Reply #18 on: November 03, 2009, 09:03:21 PM »
i think  im try find the 4.30 i dont kno of aney 16v 2 doors at all
« Reply #19 on: November 03, 2009, 09:06:03 PM »
I see some 4.30s for sale from time to time.  That would be your best bet, instead of trying to find a trackick with them in it.
Offline v-stone
  • 625
« Reply #20 on: November 03, 2009, 09:08:34 PM »
'96 was the first year they had the 16valve 2 door, but I think they had the 5.12 gears
Offline jeff5000
  • 37
« Reply #21 on: November 03, 2009, 09:12:04 PM »
actually my buddy just sold a 94 2 door auto 16 valve that i think was a 3 speed it had blown engine im have talk 2 him and se who he sold it 2
« Reply #22 on: November 03, 2009, 09:29:26 PM »
94 was the first year for 16Vs in the 2 doors.....NY and Cali spec models.
95 4x4 2 doors had the 16Vs.....the 2wd still had the 8V.
« Last Edit: November 05, 2009, 10:27:44 AM by Skyhiranger »
Offline Dillboytos95
  • 24
« Reply #23 on: November 05, 2009, 10:25:17 AM »
I Have a 95' 2 door tracker 16valve! but dont know the gearing.
95 Geo Tracker
2" Coil Spacer
31/10.50/R15
« Reply #24 on: November 05, 2009, 10:28:37 AM »
If it has an auto tranny, it should have 4.30s.  If it has a manual tranny, it should have 5.12s.
