ring and pinnion
  • 24 Replies
  • 5683 Views
Offline jeff5000
  • 37
ring and pinnion
« on: November 03, 2009, 04:32:39 PM »
will samurai gears fit in a tracker
Re: ring and pinnion
« Reply #1 on: November 03, 2009, 04:34:33 PM »
Only in the front.
Offline zukimoo
  • 330
« Reply #2 on: November 03, 2009, 04:39:34 PM »
any reason you'd want to put 373's in a tracker? Tracker stock gears are alot lower.
06 Baja Buggy
Offline jeff5000
  • 37
« Reply #3 on: November 03, 2009, 05:25:21 PM »
with samurai transfer case in tracker i cant run over 65 mph with 5.12 and 31 s
« Reply #4 on: November 03, 2009, 05:54:12 PM »
Your best bet is probably going to be to find someone with an automatic transmission and swap with them.
Did you go with a t-case doubler or with a 2wd straight into the Sammy T-Case?  Any vibrations with the rear drive-shaft?
Offline jeff5000
  • 37
« Reply #5 on: November 03, 2009, 07:42:05 PM »
home made dubler sami rear shaft rite length no mods had lengthen front shaft little vibs from front shaft when in 4wd shaft needs ballanced
« Reply #6 on: November 03, 2009, 08:06:58 PM »
You should be able to use samurai gears in the trackick rear too.  Just use the samurai carrier.
Offline jeff5000
  • 37
« Reply #7 on: November 03, 2009, 08:22:01 PM »
what gears do the auto tracks come with
« Reply #8 on: November 03, 2009, 08:25:06 PM »
4.62 if it has a 3 speed auto and an 8V.
4.30 if it has a 3 speed auto and a 16V.
5.12 if it has a 4 speed auto.
Offline v-stone
  • 625
« Reply #9 on: November 03, 2009, 08:37:13 PM »
unless the the rare 1.3liter sidekick has the smaller bolt pattern than other sidekick/trackers the sami third will not fit in the rear, its a different bolt pattern and bolt size. I have both thirds sitting side by side in the garage and everything about the sidekick rear third is bigger. Are you saying you can blend them ??? ??? ???
I've got the dual t-case (home brewed) in mine also. If you put the 4.62 from the 2 door early autos you'll bump up from 65 to 72. That was my plan before my engine blew.
SAS Tracker! No looking back now.
Offline jeff5000
  • 37
« Reply #10 on: November 03, 2009, 08:41:30 PM »
im going 2 look 4 the 4.30 i think that make it about right i dont want blow my engine a nother 85$ 2.0 will be hard 2 find  :(
« Reply #11 on: November 03, 2009, 08:46:04 PM »
4.30s can be hard to find.  They are found in 2 door trackicks with the 16V and the 3 speed auto.....that combo is only found in some 94s and 95s.  I have heard that some people have found them in the 8V trackicks of those years too.....but I never have.
« Reply #12 on: November 03, 2009, 08:49:09 PM »
The 1.3 sidekicks had the large rear thirds, just like any other trackick.
From what I remember, the distance between the carrier bearings are the same (or close enough) that you can use a samurai carrier in a trackick rear third.  The bearings are the same size, so there will not be any issue with the bearing caps.  And the pinion bearings are the same size too, so a samurai pinion will fit in a trackick rear third just fine.
Edit.....I am going to have to think about this.....even though the carrier bearing spacing is the same, the pinion depth would be off, because of the smaller ring gear of the samurai.  I must be thinking of using samurai carriers in the front of trackicks, not in the rear.
« Last Edit: November 03, 2009, 08:54:18 PM by Skyhiranger »
Offline v-stone
  • 625
« Reply #13 on: November 03, 2009, 08:51:45 PM »
I believe the grang vitaras have the higher ratios too.
Offline jeff5000
  • 37
« Reply #14 on: November 03, 2009, 08:52:46 PM »
what do the 4 door auto 16v kicks have
