steering stab 87 sammi
  • 1878 Views
« on: November 06, 2009, 03:24:47 AM »
where can i get a replacement steer stab, dont need a $100 bolt on
thanks
Re: steering stab 87 sammi
« Reply #1 on: November 06, 2009, 11:06:46 AM »
You should be able to get a stabilizer kit from your local parts store for a decent price.  Does your Samurai not have a stabilizer at all or does it just require replacement?
I use a Toyota mini pickup stabilizer on my SJ and custom made a mount off of the pitman arm running to the other side of the frame.  It works fine, even if it does add a bit of resistance to the steering.  Before that I didn't run one at all for years, the BFG tires were light enough and balanced themselves out to the point it wasn't required.
« Reply #2 on: November 08, 2009, 05:20:13 AM »
It has one from factory, just can't find a replacement at local p stores
Offline dupont#24
  • 48
  • Deer hunter
« Reply #3 on: November 08, 2009, 06:32:07 PM »
4wheel parts.com you will have to buy the kit that bolts to your axle .Skyjacker is what I bought It was a big difference to.
