Jerrys can
  • 14 Replies
  • 3607 Views
Jerrys can
« on: July 27, 2004, 03:47:30 PM »
I decided it was time to carry a little X-tra gas, being when your off-raod your milage seems to go down a little. ;D
The bracket as been modified to cary a small can or a big can (short trip or long trip)
The bracket is bolted to the swing a-way bumper, It blocks the rear plate but I'll think of something one day ;D
small can- 2.5 gal - Short trips.
Big can - 5gal - longer trips
My license plate may go down onto the bumper with a little light (just to stay legal ;D)
Thanks Explosivo ;D
« Last Edit: July 27, 2004, 03:48:28 PM by trickker »
Offline explosivo
  • 3157
Re: Jerrys can
« Reply #1 on: July 27, 2004, 03:50:32 PM »
Sweet. Where'd you get the big jerry can, and how much?
omghi2.us[/url]
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: Jerrys can
« Reply #2 on: July 27, 2004, 04:01:37 PM »
Nice :)
Re: Jerrys can
« Reply #3 on: July 27, 2004, 04:04:27 PM »
I found the big jerry-can at an Auto parts store for 28 bucks  :P
It was cheaper than most off-raod shops, 37 bucks. :o
My little bro rebuilt poart of the can holder to hold a square 2.5 gal can. Just incase I don't need the added weight of a 45lb (5gal) can.
8lbs a gal for water and I'm sure gas wieghs alittle more ???
Bottom Two of the bolt holes are Taped into the arm and the top two may-be spot welded to the top and bolted to the can bracket.
Offline Iron_Crow
Re: Jerrys can
« Reply #4 on: July 27, 2004, 05:26:54 PM »
Actually, gasoline weighs a little less than water, about 7 lbs per gallon.  Still makes for a heavy 35 lbs plus the can...
Iron Crow  -  An X-90 with freakishly large wheels, bent on world domination!  90:1 crawl ratio and ARB front & rear
Offline shoyrtt
  • 161
Re: Jerrys can
« Reply #5 on: July 27, 2004, 06:09:37 PM »
Nice :D
Any sag in the rear with the full sized can, tire and the lift ???
Re: Jerrys can
« Reply #6 on: July 27, 2004, 06:19:36 PM »
I'm sure there will be a little more sag with a full 5 gal can on the back ;D Im still not sure if the bracket can take the full wieght (5gal) with out more support under it. Thats also on my to-do list ;D
Probly if I swing it open, I'll take the 5gal can off first.
Re: Jerrys can
« Reply #7 on: July 28, 2004, 12:11:07 AM »
Looks good Hot Rod 8) Dont forget to moove the tag, the popo will get you for that one :o
Offline MB
  • 223
Re: Jerrys can
« Reply #8 on: July 28, 2004, 10:25:43 AM »
Looks good HotRod 8)
I got mine from the Army HQ (surplus supplies) for $25.00 new. The tie down strap was missing so he let me have it at discount. I could have bought an old used od green for $15 but it was too rusty.
Re: Jerrys can
« Reply #9 on: July 28, 2004, 05:16:27 PM »
I think for now I'll tape the plate to the can and stick a flashlite on it ;D
Re: Jerrys can
« Reply #10 on: July 28, 2004, 10:30:49 PM »
;D A friend of mine wire tied his inside the rim of his spare on his Jeep. He had to trim down the edges a little for it to fit though.
Offline explosivo
  • 3157
Re: Jerrys can
« Reply #11 on: July 29, 2004, 12:58:38 PM »
Hey, I didn't realize you were from Michigan.. whereabouts are you located?
omghi2.us[/url]
Offline MB
  • 223
Re: Jerrys can
« Reply #12 on: July 29, 2004, 02:14:04 PM »
Explosivo, I'm in Midland county 5 miles N.east of Coleman Mi. Close to the Gladwin/Midland county line.  :)
Offline explosivo
  • 3157
Re: Jerrys can
« Reply #13 on: July 29, 2004, 02:28:30 PM »
Ah... I'm in Charlevoix county, about 7 miles east of Boyne Falls... soon to be in Grand Rapids (2 weeks) :)
omghi2.us[/url]
Re: Jerrys can
« Reply #14 on: July 29, 2004, 04:20:05 PM »
Hers my rear plate :-/
I think its to noticable ;D
I even put a little lite (little as I could ;)) by it
I have it mounted to the bumper were it angles back  ;)
It should keep Johnny law  (yes, I even know a John in law inforcement industry but not that good) off my tail
