1.6 16 valve
  • 10 Replies
  • 3994 Views
Offline jawman
  • 406
  • 1234
1.6 16 valve
« on: November 07, 2009, 09:12:11 AM »
I am doing a head swap on a 1.6 16 valve motor. My question is can I use the old head bolts or do I need new ones?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline zukimoo
  • 330
Re: 1.6 16 valve
« Reply #1 on: November 07, 2009, 02:11:28 PM »
worked in the fastener business for years and once they get torqued they are supposed to be changed but in a different world we re-use them all the time. I've done many and never changed one.
They will all tell you to re-use and we all do it...is it right?
06 Baja Buggy
Offline Amilla
  • 1076
Re: 1.6 16 valve
« Reply #2 on: November 07, 2009, 06:51:38 PM »
zukimoo said it right.
Its "recommended" that you go with new ones.
I to have gone with old ones and seen many other people go the same rout.
So far no one has run into a problem.
Amilla
Offline jawman
  • 406
  • 1234
Re: 1.6 16 valve
« Reply #3 on: November 11, 2009, 09:07:47 AM »
Well I am cheap, so I will use the old ones. sense I have never done this before is there a book I should get to see what to torque the bolts and time the motor right when I put it together?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: 1.6 16 valve
« Reply #4 on: November 11, 2009, 11:48:52 AM »
The best thing to do is pick up a Factory Service Manual (FSM).
The second best is to jump over to Acks Faq (www.acksfaq.com) and check out the FSM on-line.
Offline jawman
  • 406
  • 1234
Re: 1.6 16 valve
« Reply #5 on: November 13, 2009, 09:33:26 PM »
sense I have more than one car I think it would be wise for me to get a manual. I don't know where I would find one though.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: 1.6 16 valve
« Reply #6 on: November 13, 2009, 10:04:11 PM »
Ebay!
It will probably give a bolt length spec. If yours r longer you must replace.
torque spec is likely to be an angle in degrees.
Offline jtgh
  • 10
    • my Sidekick page, focused on EFI and more.
Re: 1.6 16 valve
« Reply #7 on: November 15, 2009, 11:53:14 PM »
napa has a new set for $20 ,
with no allen wrench hex key tops.
best deal around. and they do get weaker ever time you heat cycle the motor.
but nature is forgiving , sometimes
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: 1.6 16 valve
« Reply #8 on: November 16, 2009, 07:39:37 AM »
Amilla
Yes I have always been told to use new ones, but I was forced in a pinch one time to re-use the old ones and I never had a issue.
Offline jawman
  • 406
  • 1234
Re: 1.6 16 valve
« Reply #9 on: November 18, 2009, 07:54:00 PM »
well I am in a little pinch. the parts are $400 plus head bolds if I can afford it.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: 1.6 16 valve
« Reply #10 on: November 22, 2009, 06:36:47 PM »
Best you can do is to make sure the threads are cleaned of all old locking
compound and the block holes are chased with a tap so they are clear of
any rust or locker, then oil the threads and head  before you put the bolts in
